2010 Summit 800R Mid Range Bog
P
Nov 4, 2013
2
48
Indiana
Have a 10 Summit 800R. Riding in 8-11k elevation. Started to have a mid range engine bog (5300 - 6200 rpm). This started late last season. Took everything apart and checked all the typical problem areas - clutch, airbox - no issues. Read up on here to check the DPM solenoid. I pulled it apart and checked with a 12v battery, it appeared to be working correctly.
Riding again this season in 8-11k again, same mid range bog. Pulled DPM and checked with 12v battery - appeared to be working correctly. Replaced DPM solenoid and problem solved. Hope this helps.
