Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 09-20-2015, 12:19 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Exclamation IMPORTANT REMINDER...AXYS-MOUNTAIN SLEDS WITH CHAINCASES (ALL 3"-LUG FROM FACTORY)
Since many of us have had a 2013-15 QuickDrive™ equipped PRO-RMK sled... that doesn't have an adjustment for belt tension.... I'd thought that I'd put this up here.
For 2016... ALL factory 3"-lug equipped mountain sleds... in both 163" and 155", the AXYS-SKS and the Assault all have chaincase drive systems.
The drive-chain tension needs to be adjusted periodically... ESPECIALLY FOR THE FIRST FEW RIDES.
The Borg Warner HYVO chains... which are extremely durable/tough/strong... need to be adjusted as they take a slight stretch from use.
If the chain is allowed to become slack... this can cause the chain to get jammed up in the case...and cause problems... or break from going slack-to-tight in a "snap"...
This "out of adjustment" condition is where most (of the very few) chain failures originate... the other small amount can come from defective parts, incorrect chain pitch for a gearing combo, running out of oil, worn out parts, alignment problems from an accident, etc. Very rarely have I seen or heard of a chain breaking that did not fit into one of these descriptions... and most often, it was simply never being adjusted.
Heck, I've heard people on the hill bragging "I've never touched my adjustment on the last 20 sled's I've owned, and never had a problem"... like it was some kind of badge of courage.... ADJUST THEM from time to time.
Also... with much use, the adjuster shoe gets a worn and will need to be compensated for... especially if the chain is too tight. That is what most of that brown powder is in the oil when you change the oil... a phenolic plastic that the shoe is made of. With a lot of use... that shoe should be replaced.
With the 3" tracks... the load on the drivetrain will be higher... probably a good reason that they went with the chain in the first place on these tracks.
With that increased load... they will be less tolerant of poor maintenance of the chain tension... so check that tension often!!
I like to change the oil after the first 5 rides ... after the chain and gears have broken in to each other... and get those metal particles out of the case... Heck... If have some time... I like to pull the muffler and pop the sled on its side to open up the case... look around and clean things up well. (but not necessary)
As a note.. for all those nit-picky members... the 3"-lug tracks from the factory are all 162" or 156"
Click image for larger version
__________________
Signature:
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to mountainhorse For This Useful Post:
Nooby (09-20-2015)
  #2
Old 09-20-2015, 12:31 PM
Default
For anyone working on their sled... a spring tool is great for removing the exhaust springs... for example, when removing the muffler.
Although there are a lot of them out there (pre-made and "home-made") ...and many are great... I like the one from Motion Pro.
http://www.motionpro.com/motorcycle/partno/08-0127/
WPS # 57-8127
__________________
Signature:
  #3
Old 09-20-2015, 03:00 PM
Staple_STI Staple_STI is offline
Currently: Not set.
Basic Member
Staple_STI has a reputation beyond reputeStaple_STI has a reputation beyond reputeStaple_STI has a reputation beyond reputeStaple_STI has a reputation beyond reputeStaple_STI has a reputation beyond reputeStaple_STI has a reputation beyond reputeStaple_STI has a reputation beyond reputeStaple_STI has a reputation beyond reputeStaple_STI has a reputation beyond reputeStaple_STI has a reputation beyond reputeStaple_STI has a reputation beyond repute
Default
Great info, but any insight on correct procedure for tension of the chain? I've heard finger tight, then back it off 1/4 turn??
  #4
Old 09-20-2015, 03:22 PM
Default
Quote:
- Rotate the driven clutch counter-clockwise to move all chain slack to the tensioner side.
- Lock the brake lever lock, or have an assistant hold the brake lever firmly.
- Loosen the adjuster bolt jam nut.
- Finger tighten the adjuster bolt until it can no longer be adjusted by hand, then back off 1/4 turn.
- Tighten the jam nut while holding the adjuster bolt. Torque to 21 ft. lbs. (28 Nm).
__________________
Signature:
The Following 3 Users Say Thank You to mountainhorse For This Useful Post:
Clumax (09-21-2015), Nooby (09-21-2015), volcano buster (09-21-2015)
  #5
Old 09-21-2015, 09:01 AM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is online now
Currently: Waiting for my Polaris 850!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
Default
So it IS a 162!
The Following User Says Thank You to AKFULLTHROTTLE For This Useful Post:
mountainhorse (09-21-2015)
  #6
Old 09-21-2015, 11:58 AM
Default
The factory 3"-lug tracks ARE a 3" pitch... the lengths will be in 3" increments...
162" = 54 rows of paddles... 156" = 52 rows of paddles.
Polaris simply chose to standardize the measurements and call them a 163" or a 155"... in line with their other offerings.
Ski Doo, which runs the same 2.86" pitch in many of their factory mountain sleds calls the same length track a 154" where Polaris calls it a 155"... but they are the same length of 154.44" long.
__________________
Signature:
  #7
Old 09-21-2015, 12:06 PM
Default
I really like to open up the chaincase on the first oil change... to check on everything.. pretty quick process actually... and you can clean things really well.
__________________
Signature:
  #8
Old 09-21-2015, 04:42 PM
icr icr is offline
Currently: on another forum
Basic Member
icr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond repute
Default
Haha, suckered me in with the click bait title. Warning? There must be a service bulletin or something important! Nope, friendly reminder that mechanical things need maintenance. Well played buzzfeedhorse.
The Following 3 Users Say Thank You to icr For This Useful Post:
mountainhorse (09-21-2015), Sheetmetalfab (09-21-2015), Snowmow (09-21-2015)
  #9
Old 09-21-2015, 06:38 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Getting the R6 snowbike ready......
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
Warning!!!!!
It is......
As it ever was......
Carry on.
I like that name. Buzzfeedhorse.
__________________
Try again
The Following 2 Users Say Thank You to Sheetmetalfab For This Useful Post:
mountainhorse (09-21-2015), Snowmow (09-21-2015)
  #10
Old 09-21-2015, 06:56 PM
Default
What were you hoping for?? Gears made of potmetal?? Leaking oil seals? A built in viagra dispenser?
And it IS a good warning... especially with a factory track that will place more demand on the chain-drive than any other factory track equipped sled in the Polaris lineup.
Life is good!!
Carry on!
__________________
Signature:
  #11
Old 09-21-2015, 07:45 PM
ReTodd ReTodd is offline
Currently: Not set.
Basic Member
ReTodd has a reputation beyond reputeReTodd has a reputation beyond reputeReTodd has a reputation beyond reputeReTodd has a reputation beyond reputeReTodd has a reputation beyond reputeReTodd has a reputation beyond reputeReTodd has a reputation beyond reputeReTodd has a reputation beyond reputeReTodd has a reputation beyond reputeReTodd has a reputation beyond reputeReTodd has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to ReTodd For This Useful Post:
Proride_58640 (09-22-2015)
  #12
Old 09-21-2015, 07:49 PM
The Following User Says Thank You to Sheetmetalfab For This Useful Post:
  #13
Old 09-21-2015, 07:58 PM
icr icr is offline
Basic Member
  #14
Old 09-21-2015, 08:09 PM
  #15
Old 09-21-2015, 08:32 PM
  #16
Old 09-21-2015, 08:55 PM
Snowmow's Avatar
Snowmow Snowmow is online now
Currently: Not set.
Snowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond repute
The Following User Says Thank You to Snowmow For This Useful Post:
  #17
Old 09-21-2015, 08:56 PM
  #18
Old 09-21-2015, 09:04 PM
Snowmow's Avatar
Currently: Not set.
  #19
Old 09-21-2015, 09:30 PM
  #20
Old 09-21-2015, 10:47 PM
2XM3 (09-24-2015), mountainhorse (09-21-2015)
  #21
Old 10-01-2015, 12:28 AM
  #22
Old 10-03-2015, 07:35 PM
adamg adamg is offline
Currently: Damaging the Axys, one trip at a time
Basic Member
adamg has a reputation beyond reputeadamg has a reputation beyond reputeadamg has a reputation beyond reputeadamg has a reputation beyond reputeadamg has a reputation beyond reputeadamg has a reputation beyond reputeadamg has a reputation beyond reputeadamg has a reputation beyond reputeadamg has a reputation beyond reputeadamg has a reputation beyond reputeadamg has a reputation beyond repute
  #23
Old 10-04-2015, 03:35 AM
sledneck_03 sledneck_03 is offline
Currently: MTB season yeeeeeah.
sledneck_03 has a reputation beyond reputesledneck_03 has a reputation beyond reputesledneck_03 has a reputation beyond reputesledneck_03 has a reputation beyond reputesledneck_03 has a reputation beyond reputesledneck_03 has a reputation beyond reputesledneck_03 has a reputation beyond reputesledneck_03 has a reputation beyond reputesledneck_03 has a reputation beyond reputesledneck_03 has a reputation beyond reputesledneck_03 has a reputation beyond repute
  #24
Old 10-04-2015, 07:55 AM
Robbie's Avatar
Robbie Robbie is online now
Currently: Not set.
Paid Premium Member
Robbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond reputeRobbie has a reputation beyond repute
The Following 3 Users Say Thank You to Robbie For This Useful Post:
2XM3 (10-04-2015), mountainhorse (10-04-2015), Sheetmetalfab (10-04-2015)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — OFFICIAL WORD ON DRIVER SIZE AND GEARING ON ALL 2016 AXYS MOUNTAIN SLEDS Thread Starter — mountainhorse Forum — Polaris: AXYS Replies — 22 Last Post — 08-17-2016 03:49 PM
Thread — Do the new Axys sleds have the same drive shaft collar fix as the PRO's? Thread Starter — dude Forum — Polaris: AXYS Replies — 20 Last Post — 08-13-2015 06:57 PM
Thread — DEFINITIVE ANSWERS: GEARING COMBOS / TRACK CLEARANCE ON AXYS CHAINCASE EQUIPPED SLEDS Thread Starter — mountainhorse Forum — Polaris: AXYS Replies — 5 Last Post — 05-13-2015 04:20 PM
Thread — Warning to all 09 iq owners.....check your sleds! Thread Starter — Sled Solutions Forum — Polaris Replies — 20 Last Post — 10-12-2008 07:21 PM
Thread — Warranty Warning 07 Sleds Thread Starter — sleddin pete Forum — Ski-Doo Replies — 6 Last Post — 01-19-2008 02:34 PM
no new posts
