Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 05-03-2014, 09:37 PM
seano700 seano700 is offline
Currently: Not set.
seano700 has a reputation beyond reputeseano700 has a reputation beyond reputeseano700 has a reputation beyond reputeseano700 has a reputation beyond reputeseano700 has a reputation beyond reputeseano700 has a reputation beyond reputeseano700 has a reputation beyond reputeseano700 has a reputation beyond reputeseano700 has a reputation beyond reputeseano700 has a reputation beyond reputeseano700 has a reputation beyond repute
Default Head shim opinions
Have a viper with mcx270 on order for fall. Not sure if I should just install the shim, or go with low comp pistons. For those that run mcx what's your advise. I would be pretty happy with 220, no shim and snappy. I rode the 180's and not quite enough for a medium husky rider . Tks
Sean
Rate this post: Yes | No
  #2
Old 05-08-2014, 04:07 PM
jskattum606 jskattum606 is offline
Currently: on the path to success
jskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond repute
Default
Not very lively in the yami forum
I dont own either but have ridden with shim and without and the difference is very minimal. The 3 cyl motor makes lots of low end torque to over come any downside to lowering compression a little. With that said, I wouldnt want to open the motor all the way up just to put in another set of brand new pistons
  #3
Old 05-08-2014, 11:20 PM
BigFish BC BigFish BC is offline
Currently: Time to start breaking $hit theres snow on the ground.
BigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond reputeBigFish BC has a reputation beyond repute
Default
Quote:
Sean
you could make 220 with no shim but the prob you will have is the fueling wont be the same,so there is a good chance you would need a diff fuel map.the other issue you will have depending on elevation you will need to run about 10lbs boost to make 220hp & you will need to run at least 50/50 112/91 oct & that will be borderline without water to air intercooler.no shim does make a big diff to me but the next guy may not notice it i guess,way better throttle responce.
  #4
Old 05-09-2014, 12:56 AM
Climbmax's Avatar
Climbmax Climbmax is offline
Currently: Hello Drama and Karma...you related?
Climbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond repute
Default
I run a 270 MCX with Head shim. Its plenty snappy and I wouldn't change from their program.
Enjoy
RS
__________________
2011 Nypex, Full CR tube tunnel with Carbon skin, MCX plenum, Boost It Fuel system, 174 x 16 x 3", CR M10 skid
2008 Nytro, 270 MCX pump fuel, 174 x16x 2.5", Racers Edge Skid, CR chasis, ZBroz Front end and Shocks
Apex with MCX front mount, Full CR chasis, 174 x16 X 2.5", Racers Edge skid, Boost It fuel system
AST1
The Following 4 Users Say Thank You to Climbmax For This Useful Post:
APEXXPRESS (05-09-2014), Cpt.Ron (05-09-2014), Kibbels (05-09-2014), Tarzannr1 (05-10-2014)
  #5
Old 05-09-2014, 08:32 AM
M5- M5- is online now
Currently: Planning a build
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
Default
The shim makes a difference for sure but nearly the difference the turbo system plumbing makes. There is no doubt the mid mount Impulse sleds are snappier than the rear mount MCX ones, I've owned both, that said the MCX shimmed motors are pretty much bomb proof. I'm willing to trade off a little throttle response for the gas and go ease of everything else that the MCX kit provides. Slap in the shim, add fuel and ride it at 270, you will never be turning down the boost. There is no point in doing rods and pistons if you are only thinking 270 or less hp IMO and the 270 program is tried and true.
M5
  #6
Old 05-10-2014, 08:27 AM
Currently: Not set.
Default Thanks fellas
Appreciate your feedback!
Reliability and tinker free are the priorities with this one, so we will keep it simple with the shim.. I was considering pistons only because I want to do this once to get many years out of the machine.
Brad at mcx Canada sent me a brochure on there data logger.. From what I understand it logs, acts as a gauge, and allows the rider to tune the auxiliary fuel map.. Is this a worth while investment? I was thinking of skipping out on the A/f and boost gauges running this in it's place..
I currently have Neil's Boost-it on my Nytro, it woke that sled right up, tuning has never been so easy... Prior to this it was laptops, and cables.. Yuk..
Thanks again!
Sean
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Head Shim Question Thread Starter — Northernboy Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 4 Last Post — 12-15-2013 07:19 PM
Thread — nytro 270 head shim and head Thread Starter — speedrcr Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 1 Last Post — 03-29-2013 07:11 PM
Thread — Nytro, head shim versus no head shim questions Thread Starter — redbull660 Forum — Yamaha Replies — 17 Last Post — 05-27-2008 02:26 PM
Thread — Head shim on Nytro Thread Starter — 4strokesnewbie Forum — Yamaha Replies — 2 Last Post — 04-11-2008 07:30 PM
Thread — Head shim? Thread Starter — SAWYER Forum — Yamaha Replies — 19 Last Post — 04-10-2008 10:12 PM
no new posts
