Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 08-11-2016, 12:39 AM
bustamove bustamove is offline
Currently: the most fun you can have with your clothes on ;)
bustamove has a reputation beyond reputebustamove has a reputation beyond reputebustamove has a reputation beyond reputebustamove has a reputation beyond reputebustamove has a reputation beyond reputebustamove has a reputation beyond reputebustamove has a reputation beyond reputebustamove has a reputation beyond reputebustamove has a reputation beyond reputebustamove has a reputation beyond reputebustamove has a reputation beyond repute
Default Head shim + rebuild
Alright so from the top, I bought a 09 nytro 163 mtx6500km/4000miles, with what I'm told is a mcx 240 kit ready to go. Unfortunately I got screwed, got it home it sat for about a week or so went to start it up. Long story short, exhaust pumping out burnt coolant oil level is milky and over filled now. Hopefully rod isn't Bent, and crank is okay(can't tell clutches are so god damn noisy)
My questions are:
With the head shim is it an oem gasket above and below it? Or 1 gasket split apart, research has me more confused.
Should I replace head shim? With stainless or mcx aluminum? Pro and con to each? I emailed mcx and they want almost 200 cad for a new shim. Yet hurricane +others want 75usd ish for stainless.
Every bolt on this engine is torque to yield. Obvs head,rods, bearing caps, I'll buy new. But can you reuse the case bolts? Well we're talking about bolts are arp worth the money?
From the research I've done usually head gaskets go due to overheating or really pushing way to much boost. Anyone heard of a cracked head or block? My worst fear!
I'm coming from a polaris rmk 900, jury is still out if I'll like the nytro or not so I don't wanna sink a whole bunch of money into yet... but id like to get it running.
Rate this post: Yes | No
  #2
Old 08-11-2016, 07:36 AM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is offline
Currently: Making roll-over valve kits since 2008
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
Default
Since it has coolant in the oil and you have no way of knowing how long it was ran in this condition. I would go ahead and pull the lower case (oil pan) and rod/main bearing caps to inspect the bearings. These engines run tight bearing clearances (usually around .001") and if the oil is contaminated or ran low on oil it can damage the bearings fairly quickly.
If there is bearing damage and you try and run it, there is a chance that it could spin a rod bearing and pitch a rod through the side of the block. Normally it's the center rod that lets go first.
It's probably not the answer you wanted to hear, but I would pull the motor to do the tear down/inspection. As it sits now you have a rebuild-able engine and by tearing it down you'll know for sure if it's sound before spending more money on it.
__________________
Four Stroke Solutions LLC
Patented Roll-Over Valve Systems
ROV kits for M/XF7000/Viper, Sidewinder and King Cat with Quick-prime!
For Arctic Cat and Yamaha Sleds
Patents 8,225,766 8,528,516 9,303,537
http://fourstrokesolutionsllc.webs.com/
e-mail fourstrokesolutionsllc@hotmail.com
  #3
Old 08-15-2016, 12:44 PM
stingray719 stingray719 is offline
Currently: 2014 Viper MTX conversion
stingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond repute
Default
Having done a few I agree completely with this.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Multiple head gaskets or head shim Thread Starter — Linc Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 8 Last Post — 01-20-2015 08:03 AM
Thread — Head shim opinions Thread Starter — seano700 Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 5 Last Post — 05-10-2014 08:27 AM
Thread — nytro 270 head shim and head Thread Starter — speedrcr Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 1 Last Post — 03-29-2013 07:11 PM
Thread — Nytro, head shim versus no head shim questions Thread Starter — redbull660 Forum — Yamaha Replies — 17 Last Post — 05-27-2008 02:26 PM
Thread — Head shim? Thread Starter — SAWYER Forum — Yamaha Replies — 19 Last Post — 04-10-2008 10:12 PM
no new posts
