Note: this_feature_currently_may_not_be_available_in_some_browsers
The center of the current powerclaw track isn't strong enough to support the weight of the sled, the paddles will fold over.Would it be feasible to narrow a two rail skid, turn the drivers
around punch and clip a current power claw track to build something similar for an older sled or, is the track THAT much different that it wouldn't withstand the flex.
When looking at the track the lugs for the outer bogie wheels are still there (they aren't needed any longer). The track on these sleds is clearly an off the shelf track not specifically designed for this application.
If a track was specifically designed for this application it would not have those outer lugs, it would probably be of a different durometer and thickness, etc. I think once they design a track specifically for this application there will be benefits to be gained in traction as well as more weight to be saved.
Track tension will be paramount! I LOVE cat for giving us this... didn't share it with yammi hilarious. Super curious how how unbearable it would be on the trail to the pow, not that that matters much.
The drivers look the same as current.If the track looks like the one pictured. Is there one extrovert driver centered on the driveshaft? Is so, are there two introvert drivers on each side of the center extrovert driver?
Theres a lot of unanswered questions out there; hows it going to ride on trails/set-up conditions, durability, overall handling, etc. We will find out so enough, its a step in the right direction, someone has to take the big step and to bring change to the industry and Cat has done it.
It will be terrible in hardpack conditions but good in the Pow. It won't be long before we have a kit available to limit the motion for those conditions.
10"Anyone know the outer diameter of the rear idler wheels on the Alpha?
