These are our own boards and yes it is extruded and machined. No more ice picks loosening, breaking off or stripping! We will get more pictures on hopefully soon. Still wrapping for haydays!
Jeff
BDX
and now, my fave!!! green and white!!
OK Dave and Kevin, how much are the upgraded front shocks?????
From an engineering standpoint, the stem is going to bend when a certain force is applied to the handlebars when they are at a certain height. Doesn't matter if the stem is longer with a shorter riser or if the riser is taller and the stem is shorter.
I like those boards. From the pictures, they look narrower than stock. Are they narrower? That would be a good thing for me.
Yes they are narrower and fit great. instead of the bar on the in side the are flush with the tunnel. last year we ran the skins boards and they had a tube against the tunnel and that was the only place that ever had snow build up and this should eliminate that. then we also will not have to put screws in then since they have built in traction ribs.
Steering post sticks up same amount as last year, and the ones in picture are the HCR T-Post instead of adjustable post. You can get either one as it is an option.
Also, running boards are $399 with orange, black, white and green color options
Front bumpers are $199 with same color options.
Custom colors available for added price. Mid-October availability
