Yep.
The simple strap idea has some issues, one of which I decided was bad, one of which was pointed out above by the fact that they need to pivot or they will loosen the bolts.
1st one - A cut up M series motor plate, metal mount on one end, plate rubber bushing mount on the other. - Changed because it was pointed out that it needed to pivot, so:
2nd one - Cut the end off and scabbed on a tie rod/end. It interfered with the secondary, I placed it on the TCL without being smart, lol. Plus it was a scabbed together ugly mess as I was sick of screwing with it. Now in the metal pile.
3rd one - Easy, basic. I think it was a Poo radius rod. Cut off, rethreaded for the end. Lower end has an bushing I found that fit, then drilled out to baccept 3/8" bolt. (More on that below.) The upper is the same sized rod end, a chunk of fuel tubing that drilled out a bit that is a press fit between bolt and inner rod end. (Rubber mounted.)
Both ends can rotate, so no loose bolts. Also allows movement front to rear, which Cat put there for some reason. Only addresses lift, which from my measurements IS a problem.
Now, those lower frame bolts that people are using to mount their links, are shouldered. (For a reason.) A non shouldered bolt will alow you to tighten the bolt too much and crush the aluminum frame member. (At least how I see it.) Putting a strap under that bolt will allow you to overtighten it also, which is one thing I didn't like about my original straps. I used the rear mount bolt for two reasons. One, it is closer to 90 degrees to the tcl and the direction it lifts. Two, you can get to the rear nut of the shouldered bolt from under the sled. This is helpfull because I drilled and threaded the shouldered bolt to accept a 3/8" bolt, for tie rod mounting. (It mostly removes the allen hex hole, so you can tighten the bolt from under the sled if the allen key strips.) A smaller metric bolt stripped when I threaded it. Last thing, my rod lightly touched the belt at WFO throttle, so I bent it in the vice to tuck in better. Easy strap, wouldn't have taken a day if it was the first I made, LOL.
