98 powder special 600efi-cuts out in powder
F
Sep 1, 2008
352
30
HAVRE,MT
Here is the question- I start it up-idles fine. Warm it up for awhile-fine.
I took off in the backyard today-about a foot of powder.
Got about 200 yards- wants to cut out and almost quit.
I stopped-let it idle -fine-
took off again-hit the powder- cuts out again.
lifted the hood up-snow inside the eng compartment,on top of air box, and on the trottle body.
Is this causing my delema?
M
Nov 27, 2007
143
3
18
Make sure the throttle cable is adjusted right and not to loose. Also check the little washer on the throttle pin. Both are known trouble makers. Hope this helps.
M
Apr 15, 2008
62
13
8
Brigham City
Had the same problem, it was the internal safety switch, uplug it and see if your problem goes away. Due to the viberation over a period of time it will not operate as it did when new. Its a safety feature that cat puts in and I don't think they ever work right, I beleive, if yours is the three wire you can cut the middle wire and your kill switch will still work, if it's a two wire not sure how to get around it to make your kill switch still work...ideas anyone? Hope this helps.
M
Jul 3, 2008
1,870
659
Utah
just make sure that you tape, or heat-shrink your wire so that it doesn't ground out, otherwise it will be like hitting the kill switch.
