C
For those of you that have never adjusted your factory secondary clutch, this is for you. For those of you that are way more knowledgable than I on the subject, let me know and I'll edit this post for future viewers.
As Tony noted in the thread "things to look for", the 503 and 600 hawks may have no spring tension on the secondary. To check this remove the primary belt and roll one half of the secondary in one direction and the other half in the opposite direction. It should have a good snap when you let it go. Neither of mine had any spring tension. One of the other board members suggested that I set my secondary to the "B 6" setting. It seems to shift well.
To adjust your secondary build yourself a little tool.
Clamp the head of the bolt into a vice and slide your secondary over the bolt. Install a washer and a nut and center the two legs of the tool on the helix. Tighten the nut so the tension is off of the c-clip.
Remove the c-clip and back the nut off. Disassemble the secondary noting how the parts came apart. Remember to verify where the secondary spring is set as both ends of the spring have a hole to set in.
Now is a good time to check for wear and clean up the shaft. Both of my secondarys had a little corrosion on the shaft. I used some fine emery cloth to clean them up. If you look down into the secondary you can see the three holes in the engine side of secondary. These are labeled A, B and C. On the helix there are 6 holes and are labeled 1 through 6.
To reassemble the clutch first set the spring into the holes that you feel will work best for you. Once again I have mine set to "B" on the engine side and 6 on the helix side. When you re-install the helix you need to twist the helix. Turn the helix clockwise to get spring tension on it. I installed my helix and re-installed the nut loosly on the tool so as to have it ready to tighten when I had the spring tension on the helix. Once you have your spring tension tighten the nut down and reinstall the c-clip. Install the secondary clutch back on the secondary shaft and twist the clutch halfs in opposite directions to see how much tension you have and also to see that it is not bound up.
Thats about it. Let me know if I skipped a step or something.
Chris
Chris
