Looking for more info on Shot start
Barcode
SnoWest Sponsor
659
289
Hey guys, anyone have more in-depth info on the Shot start system. Ive gone through whats out there. We've been experimenting with Super caps on our sleds all year now. Our last test showed that the Super cap pack we are using so far has held it charge for 11 hours and then started the sled. (2013 XM) at 14.2v
Im just trying to find out what part of the Shot system is causing such a rapid drain on the Super caps? So far the only thing I can come up with is the Etec computer stays energized. Or the Super caps Doo is using are just way to small.
We'll find out this fall, as were going to be snow checking one. Thanks Christopher!!(been reading your threads) We were a pretty solid Yamaha guy. Well that and the Cat chassis the Viper has really opens our eyes. HAHA
Cheers
Allan
Teth-Air
4,561
2,789
Calgary AB/Nelson BC
www.specified.ca
Cheers
Allan
Are you using a charge resistor with your capacitors to protect the lighting coil from overloading? We use 50 Watt resistor.
27,373
Cheers
Allan
Right there with ya Allan.
LOVED my Viper.
It was a HUGE step forward for Yamaha.
But the 850 just handles SO MUCH BETTER.
And if you liked the Viper with boost, just wait till you take a boosted 850 out for a spin. OH MY >>..
Barcode
SnoWest Sponsor
659
289
The Ucaps were using are pre built onto a circuit board, that has the safely measure built in. Im not sure I would trust just the Ucpaps just on their own.
Barcode
SnoWest Sponsor
659
289
That is exactly what I have heard as well!
Thats encouraging. 30 min seems to me way to short. Since Im seeing 11 hours so far from our Ucap pack. My suspicion is the magneto or the computer is "active" so its causing a drain on the system.
What are you hearing in regards to times? 60min? 2 hours?
NHRoadking
1,669
2,047
Dave Narona has a video on Youtube on the Shot system. After waiting an hour with the sleds off, the sled started with Shot.
He said after 35 minutes with the sled off, the system goes down to 95% and after an hour, it's down to 80%.
The longest he's gone that he's posted about is two hours with the sled off, and it started up.
Norona
2,585
4,681
North Vancouver, BC
www.noronalife.com
actually more like 2.5 hours and started but then did a little over three hours and it did not start. Yes Ski-Doo is downplaying the shot system and also it works better in the warmer climate of BC over Quebec and colder places...so keeping the numbers low allows for worse case senerio
NHRoadking
1,669
2,047
That is impressive!
Dec 5, 2010
450
404
Sḵwxwú7mesh, BC
I wonder what the weight advantage of SHOT is over the G4 e-start with a light weight battery (i.e. earthx)
I'm willing to bet it's within 5 lbs ..
I love the idea of not having a starter motor ... but why didn't they use a light weight battery instead of the capacitor (probably with no weight penalty) and there would be no need for pull starting .. ever :juggle:
Barcode
SnoWest Sponsor
659
289
Hi Dave, thanks for the input. Nice to get some first hand info. Do you know why the Ucaps drain? Is it because the computer is "active or energized" for the system to work?
NHRoadking
1,669
2,047
With SHOT, you lose the starter and ring gear.
If you kept the starter and ring gear and went with a lightweight battery, you would not save as much weight.
I like the idea of the SHOT system because you get light weight and the pull start too.
Tahoe54
171
62
Cheers
Allan
So you had designed a similar system to Shot starting a little over a year ago or what were you using the super cap for?
Barcode
SnoWest Sponsor
659
289
Our's started off as a way to send more consistent voltage to the Vipers ECU. With a lower voltage it would case some issues. And the light weight Lithium batteries were horrible in super cold weather. So we were looking for a alternative.
B
Feb 18, 2009
233
150
Keep in mind with the Shot you NEED a pull start whereas with the ES you do not so that can be another 5 lbs or so for the Shot system. I know a lot of people add a recoil to ES models for backup but I bet 99% have never used it other then if they let their battery die.
As for why they didn't just use a battery for Shot or a hybrid ES is because the battery probably can't release the same amount of power in a burst like the capacitors can...
I hate starting code sleds in an enclosed trailer (limited room to pull) so I'm going with the ES and will likely add a EarthX battery at some point to bring down the weight...
Tahoe54
171
62
Interesting, were you guys selling this in a kit at all?
madmax
3,145
Salt lake city
The 850 doesn't really use a ring gear (clutch mounted) like the traditional sled e-start. The starter engages the flywheel on the magneto. The teeth on the flywheel I'm pretty sure aren't removable.
