Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 01-14-2015, 04:26 PM
Catrider144 Catrider144 is offline
Currently: Not set.
Catrider144 has a reputation beyond reputeCatrider144 has a reputation beyond reputeCatrider144 has a reputation beyond reputeCatrider144 has a reputation beyond reputeCatrider144 has a reputation beyond reputeCatrider144 has a reputation beyond reputeCatrider144 has a reputation beyond reputeCatrider144 has a reputation beyond reputeCatrider144 has a reputation beyond reputeCatrider144 has a reputation beyond reputeCatrider144 has a reputation beyond repute
Default 2013 change chain case oil?
I recently bought a 2013 M800 Sno Pro with 550 miles on it. The chain case oil has never been changed. I have always had an older M series sled, so changing the oil on that was not a problem. I can't figure out how to do it on this sled. Anyone have some advice or info on ho I change this? Thank you
Rate this post: Yes | No
  #2
Old 01-14-2015, 05:22 PM
RACINSTATION's Avatar
RACINSTATION RACINSTATION is offline
Currently: Working on 2018 Proclimb mods
RACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond reputeRACINSTATION has a reputation beyond repute
Default
Pull the toe stop piece out of the rh side. 4 T20 torx bolts. Remove the 1 T20 torx that holds the rh side panel to the foothold so you can pull it toward you. Then just remove all the T30 torx bolts that hold the chaincase cover on (remove it WITH the oil tank). There are a couple holes in the chaincase protector that will allow the oil to drain out. CHECK CHAIN AND TENSIONER. Clean up the belly pan and reassemble and fill with oil.
__________________
The Racin Station
60 South 1st Street Driggs, Idaho 83422
Ph: 208-354-2777 E-Mail: racinstation@hotmail.com
The Racin Station is your TURBO MOD HEADQUARTERS
for Arctic Cat Proclimb 8000/1100 and Yamaha Vipers and Sidewinders!
TIMBERSLED FULL LINE DEALER!!!
Proclimb Carbon Fiber Vents
Your MDS weight headquarters
Team ProClimb secondary complete setups ready!
Reman M6,M7,M8 and M1000 cylinders in stock.
Jaws M8 Singles for the 2012-2017 in stock!
Jacobsen Rollover valves in stock for M1100Turbo and Viper/M7000!!
Camoplast 3" and 3.2" 174, 162 and 156 x15 tracks on hand now
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to RACINSTATION For This Useful Post:
Catrider144 (01-15-2015)
  #3
Old 01-14-2015, 05:38 PM
ArcticKing ArcticKing is offline
Currently: Not set.
ArcticKing is an unknown quantity at this point
Default
I still have the stock can on my sled so it was in the way. I ended up taking off the hood to remove the pipe/can then did exactly as racinstation said.
  #4
Old 01-15-2015, 08:15 AM
Currently: Not set.
Default
Thanks for the info. Stupid question though. Does the oil in the tank not drain out?
  #5
Old 01-15-2015, 09:03 AM
arctic2009 arctic2009 is offline
Currently: working on sleds
arctic2009 has a reputation beyond reputearctic2009 has a reputation beyond reputearctic2009 has a reputation beyond reputearctic2009 has a reputation beyond reputearctic2009 has a reputation beyond reputearctic2009 has a reputation beyond reputearctic2009 has a reputation beyond reputearctic2009 has a reputation beyond reputearctic2009 has a reputation beyond reputearctic2009 has a reputation beyond reputearctic2009 has a reputation beyond repute
Garage
Default
Quote:
No, you need to keep the oil reservoir mounted on the outside of the chain case cover. Make sure you are only taking the chain case cover screws out. You can leave the oil line hooked up to the reservoir and just move the whole assembly out of the way instead of un-hooking the line etc. When reinstalling the screws make sure you put them all in by hand before tightening them down, those ears on the cover can break off pretty easy.
The Following User Says Thank You to arctic2009 For This Useful Post:
  #6
Old 01-15-2015, 09:46 AM
Currently: Not set.
Default
OK, sounds good. Is the gasket re-usable or should I pick one up before taking it off?
  #7
Old 01-15-2015, 10:54 AM
Spltd Spltd is offline
Currently: Waiting for snow
Basic Member
Spltd has a reputation beyond reputeSpltd has a reputation beyond reputeSpltd has a reputation beyond reputeSpltd has a reputation beyond reputeSpltd has a reputation beyond reputeSpltd has a reputation beyond reputeSpltd has a reputation beyond reputeSpltd has a reputation beyond reputeSpltd has a reputation beyond reputeSpltd has a reputation beyond reputeSpltd has a reputation beyond repute
Default
I've always just re used mine I wouldn't change it unless it's damaged
The Following User Says Thank You to Spltd For This Useful Post:
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2013 xm chain case Thread Starter — Skidoo70 Forum — Ski-Doo: XM Sleds Replies — 6 Last Post — 02-10-2013 11:26 PM
Thread — Chain Case Oil Change Rev XM Video Thread Starter — Norona Forum — Ski-Doo: XM Sleds Replies — 0 Last Post — 12-31-2012 01:47 PM
Thread — Can I keep the oil in chain case during gear change? Thread Starter — cpa Forum — Arctic Cat: Proclimb M Replies — 8 Last Post — 02-21-2012 11:35 AM
Thread — Chain case blew apart. should I change gearing? Thread Starter — Destroyer Forum — Polaris: Pro-Ride Replies — 9 Last Post — 02-01-2012 09:13 AM
Thread — Summit 800 2003 Chain Case Oil Change Thread Starter — Dag19 Forum — Ski-Doo: ZX Sleds Replies — 12 Last Post — 12-28-2009 11:24 PM
no new posts
