2014 Polaris Pro 800 163 Questions
B
Dec 14, 2010
179
13
18
29
Looking at potentially buying a 2014 Polaris 800 Pro RMK 163” with 1200 miles. Clean title. Owner says clean with no issues. I should be able to get it for under $4k
My main question is what is the general consensus about the 14’ 800 pros? Reliable? Problematic?
And I would like to run a compression test on the sled but I don’t have a tester and neither does the owner. Do I need to buy a specific type of tester that will screw into the spark plugs holes? Or will any automotive compression tester work?
What PSI should I be looking for?
Anything else specific I should be looking for on the sled?
Thanks all
Big10inch
926
888
93
Thanks all
Great sled, great price.
You should pay a shop to do a leak down test. The compression can test good on bad rings. The leak down will tell you the real condition of the engine.
It is probably going to need a top end soon, the leak down will give you an idea how soon. Look into the Mtn Tek fix kits or even better yet call Indy Dan and get a price on a refresh.
My 14, and a lot of others had issues with the TPS (throttle position sensor) They seem to be tricky to get adjusted right but by now I think most shops can handle the issue pretty easily. The symptom is low or erratic idle speed often not allowing the sled to go into reverse.
B
Dec 14, 2010
179
13
18
29
Thanks for the info. I’m also considering another 14’ pro 800 that only has 600 miles. Get it for the mid $4k
How hard is it to adjust the TPS myself? And for a compression test do I just need a standard compression tester or one with septic threads for snowmobiles?
