Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 03-11-2019, 07:57 PM
mc2stroke's Avatar
mc2stroke mc2stroke is offline
Currently: Not set.
mc2stroke has a reputation beyond reputemc2stroke has a reputation beyond reputemc2stroke has a reputation beyond reputemc2stroke has a reputation beyond reputemc2stroke has a reputation beyond reputemc2stroke has a reputation beyond reputemc2stroke has a reputation beyond reputemc2stroke has a reputation beyond reputemc2stroke has a reputation beyond reputemc2stroke has a reputation beyond reputemc2stroke has a reputation beyond repute
Default 2015 800 Pro RMK with Broken driveshaft
I have a 2015 800 Pro RMK with 4000 miles that I just sheared the drive shaft. Are people still having an issue with these? I did not hit anything to break it I just rolled on the throttle starting into a powder carve.
Just curious if these are still coming apart? Also is there any after market fixes that are more durable then the stock drive shaft that seem weak in my opinion.
Thanks,
Brent
__________________
mount'n, ride'n, jump'n one tub of country crock at a time.
Rate this post: Yes | No
  #2
Old 03-11-2019, 08:08 PM
SRXSRULE SRXSRULE is offline
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
Default
Not very often, but you still hear about one breaking every now and then.
You can always put a steal OEM polaris shaft in it and have it fixed for good.
  #3
Old 03-12-2019, 12:04 PM
mc2stroke's Avatar
Currently: Not set.
Default driveshaft
Sounds like a good way to go. Is it a direct swap out cuz that would be easy enough.
__________________
  #4
Old 03-12-2019, 01:48 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Default
Note: Drivers do not swap out from the hex shaft of the ProRmk to the steel shaft of other models.
That being said... a good alternative is to run the steel shaft as pointed out above.
You can use any 2011 - 2115 Steel RMK driveshaft in the belt drive models.
I HIGHLY recommend that you replace the bearings on the shaft regardless of the model you use.... so that they are fresh... while you have it out... Make sure you can do the process properly and have the right tools to press off/on the new bearings ... obviously no seal is needed on the belt drive sleds.... the steel shafts have different chaincase bearings, unsealed, and need to run the sealed bearings of the belt drive shaft.
IMO...REPLACE BOTH bearings!!
good units on ebay.
Example
https://www.ebay.com/itm/382795489447
__________________
Signature:
WANT TO BUY:
Good to excellent 162 x 15" x 3" Camoplast X3 track.
Please PM me if you have one to sell, with photo, price and location
... must be willing to properly roll/strap... and ship. Thanks in advance.
  #5
Old 03-12-2019, 06:46 PM
mc2stroke's Avatar
Currently: Not set.
Default
thanks guys. Got it. 2011-2015 steelshafts (chain case model). I agree with the new bearings thought process as well. I was thinking of about replacing my jack shaft bearings while I had it out.
crazy the splined protion is what sheared off
__________________
  #6
Old 03-13-2019, 10:24 AM
xj1978's Avatar
xj1978 xj1978 is offline
Currently: I do my own stunts!
xj1978 has a reputation beyond reputexj1978 has a reputation beyond reputexj1978 has a reputation beyond reputexj1978 has a reputation beyond reputexj1978 has a reputation beyond reputexj1978 has a reputation beyond reputexj1978 has a reputation beyond reputexj1978 has a reputation beyond reputexj1978 has a reputation beyond reputexj1978 has a reputation beyond reputexj1978 has a reputation beyond repute
Default
Bearing locked and ate the end of the shaft. My 13' did it and I just replaced the driveshaft with a low mile 2014-15 takeoff. No issue since. You could always look for and axys shaft also and swap to the 2.6 if you could find a good track!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2015 Pro RMK 800 LE 163 Thread Starter — jtt454 Forum — Polaris (Swapmeet) Replies — 0 Last Post — 02-03-2018 03:52 PM
Thread — KC711 film/backcountry 2015 PRO RMK 800 155”, 800 miles Thread Starter — Polaris 711 Forum — Polaris (Swapmeet) Replies — 1 Last Post — 05-11-2015 03:08 PM
Thread — 2015 pro rm. broken drive shaft Thread Starter — tigedoo Forum — Polaris: Pro-Ride Replies — 3 Last Post — 02-17-2015 06:38 PM
Thread — For Sale, 2015 sno check 800 or 2011 800 Pro RMK? Thread Starter — towny Forum — Polaris (Swapmeet) Replies — 3 Last Post — 10-20-2014 09:14 AM
Thread — '12 PRO Broken Driveshaft Thread Starter — braapin Forum — Polaris: Pro-Ride Replies — 2 Last Post — 03-19-2012 09:59 AM
no new posts
