Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 02-12-2019, 05:48 PM
tommyboy7210 tommyboy7210 is offline
Currently: Not set.
tommyboy7210 is an unknown quantity at this point
Default Kurt's Polaris Pro RMK Gear Down Kit 15 Pro 800 Thoughts?
Hello, I'm new to sledding and the forum, I purchased a really nice low mile 15 800 Pro Terrain Dominator Edition. It has an aftermarket can and 10-60 weights on the clutch. I weigh about 300 lbs with all gear, bags, pack etc. and have been riding 9000' to 10500' Utah Unitas. The sled runs great, no problems, but looking for more low end grunt to get the sled moving. The RPM's will flash up to about 8000-8150 and pulls strong but just looking for more bottom end and mid range power and response. I would think this kit would do the trick but looking for some input from any current users of the Kurt's Kit. Thanks Tom
Rate this post: Yes | No
The Following User Says Thank You to tommyboy7210 For This Useful Post:
BillD (03-21-2019)
  #2
Old 02-12-2019, 06:19 PM
kanedog kanedog is online now
Currently: Undefeated Mountain Clutching Champ of the World!
kanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond repute
Garage
Default
Any gear down on a polaris 800 will greatly benefit low, mid and high rpm ranges. Go as low as humanly possible.
Sent from my SM-G920W8 using Tapatalk
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to kanedog For This Useful Post:
BillD (03-21-2019), kanedog (02-13-2019), sledhed (02-12-2019), tommyboy7210 (02-13-2019)
  #3
Old 02-12-2019, 10:06 PM
sledhed's Avatar
sledhed sledhed is offline
Currently: Done riding my new-to-me 17 Axys 162 CamoX 2.7 LE Titanium Orange for the season...
sledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond reputesledhed has a reputation beyond repute
Default
You would have to call Kurts to see if they still stock them for the Pro-ride chassis. I have run them on 2 sleds now and my buddy runs one also and they are great... it will throw your speedometer off a bit. I have a speedo-healer on mine, most people don't care, I didn't want to be stacking up more miles than I was already LOL. With the speedo-healer on and adjusted pretty close, I was still able to hit 81mph chasing down my buddy on the trail, and I don't believe I was max'd out...
If you can't get one from Kurts, you may be able to pick one up used, just beware of any damage or cracks that may be present on used. You never know if they have taken a hit or something. The other alternative is TKI. I have to admit I like their stuff however taking out the bolts necessary to install their tensioner brackets was a huge PITA (had to heat them to glowing to release the Lords adhesive Polaris put on them), and once I got them out I realized the battery box brackets would have to be heavily modified to work... so I gave up and sold off the TKI I had picked up and went with Kurts - no tensioner on this system...
__________________
Snowest forums member since December 19, 2001...
Member:Missoula SnowgoersMontana Snowmobile Association
The Following 3 Users Say Thank You to sledhed For This Useful Post:
BillD (03-21-2019), squillus (03-28-2019), tommyboy7210 (02-13-2019)
  #4
Old 02-13-2019, 07:15 AM
2XM3's Avatar
2XM3 2XM3 is offline
Currently: 2017 Axys 174 Turbo, 2016Axys 163
2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute
Default
Just get a set of pro sprokets, they fit perfect and drop the ratio at pretty low cost
__________________
2013 and 2014 National Superboat Champions
  #5
Old 02-13-2019, 07:44 AM
Dazzler's Avatar
Dazzler Dazzler is offline
Currently: Hobbling on crutches
Dazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond repute
Default
Quote:
The 15 is a pro..
Quote:
I've put Kurts kit on a couple Polaris pro's, I think they are one of the best mods you can do to wake them up, and Kurt is great to deal with.
The Following 3 Users Say Thank You to Dazzler For This Useful Post:
2XM3 (02-13-2019), BillD (03-21-2019), tommyboy7210 (02-13-2019)
  #6
Old 02-13-2019, 07:46 AM
2XM3's Avatar
Default
ah missed that, thanks !
__________________
The Following User Says Thank You to 2XM3 For This Useful Post:
  #7
Old 02-13-2019, 04:00 PM
Currently: Not set.
Thumbs up I just ordered one!
Thanks for the responses I just ordered a kit! Tom
Teth-Air (03-18-2019)
  #8
Old 02-13-2019, 04:12 PM
sledhed's Avatar
Default
You won't regret it... really makes these sleds pull hard off the bottom end. I ended up getting a clutch kit from them too but it isn't required by any means... sled pulls hard either way. Did you order it out of Seeley or Missoula Kurts? I know the guys in Missoula a bit better but they are all great.
__________________
The Following User Says Thank You to sledhed For This Useful Post:
  #9
Old 02-13-2019, 06:36 PM
Currently: Not set.
Default Kurt's
I'm not sure which location just called the Montana number posted under the kit on their website. Larry answered and transferred to Mike in the parts dept. Super quick and easy to deal with, already shipped out too! Tom
  #10
Old 02-13-2019, 09:29 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
The Following User Says Thank You to Scott For This Useful Post:
tommyboy7210 (02-14-2019)
  #11
Old 02-14-2019, 04:47 PM
PSI 800 PSI 800 is offline
Currently: waiting to tear up the mtns
Basic Member
PSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to PSI 800 For This Useful Post:
  #12
Old 02-14-2019, 10:56 PM
sledhed's Avatar
Scott (02-16-2019)
  #13
Old 03-18-2019, 12:31 PM
Currently: Not set.
  #14
Old 03-18-2019, 02:27 PM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
  #15
Old 03-18-2019, 03:00 PM
Scott's Avatar
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 13–15 Pro RMK Kurt’s Polaris geardown kit Thread Starter — Rotax800Summit Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 01-09-2018 07:33 PM
Thread — Kurt's Polaris Gear Down Kit. Thread Starter — Griff Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 10-24-2017 07:01 PM
Thread — Kurt’s Polaris RMK belt drive gear down kit---SOLD!!! Thread Starter — kylant Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 11-12-2015 01:15 PM
Thread — Kurt's Polaris Gear Down Kit? Thread Starter — m1kflyingtiger Forum — Polaris: Pro-Ride Replies — 210 Last Post — 10-21-2015 10:42 AM
Thread — kurt polaris gear down kit, for Pro,new,$550 Thread Starter — 2mileshigh Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 3 Last Post — 04-06-2015 10:33 PM
no new posts
