Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 01-26-2017, 06:51 PM
rulonjj's Avatar
rulonjj rulonjj is offline
Currently: Current in the current current.
rulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond repute
Default Axys bogging
I have an axys 155 I bought used with 1200 miles. It hasn't run right from the day I bought it. First of all it wouldn't idle. I had to keep some throttle in it for it to run. And it ran rough. Super rough. So I took it to the dealer and got the tps adjusted so now it idles but it's still really rough and it bogs. It bogs from 2000 to 5000 rpm then it has a spot up to 6000 that it runs good and then it bogs again from 6000 up to 6500 and it won't go any higher than that. The bottom end bog is always there. The top end bog comes and goes. Also it will not go over 8,000 rpm. It hits 8000 at 6,000 ft and it hits it at 11,500 ft elevation. It don't matter what elevation it's at it just goes to 8000 rpm. It's been to the dealer 3 times and he is at his wits end. We have checked every wire, replaced every relay and greased every connection. Power valves have been cleaned as well. Anyone here have to deal with this kind of problem?
Rate this post: Yes | No
  #2
Old 01-26-2017, 07:39 PM
Indy_500's Avatar
Indy_500 Indy_500 is offline
Currently: Going Left!
Indy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond reputeIndy_500 has a reputation beyond repute
Garage
Default
Reeds?
__________________
-2016 Polaris Pro RMK 800 LE 155" x 2.6"
~Raptor Shocks, 37" Raptor Front End, Zollinger Billet Spindles, 2.5" Camo Extreme, Bikeman Pipe, HPS Can, and more.
-2004 Polaris Pro X2 600
-2003 Polaris Pro X 600
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 01-26-2017, 09:16 PM
ak ak is online now
Currently: Nothing
ak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond repute
Default
You say Power valves cleaned have they been adjusted by a dealer?
  #4
Old 01-27-2017, 01:02 AM
G-Force's Avatar
G-Force G-Force is offline
Currently: Parking the pro and polishing the CVO..
G-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond reputeG-Force has a reputation beyond repute
Default
Yikes what a nightmare. Buy it form a dealer, or private? If it ran like that from day one, I'd like to think a dealer would have taken it back? Or in a perfect world, not sold it at all as they would have tested it..
If bought private, not a lot can do now, except hope you get it running great asap, as the sled really is something when working properly..
Clutches pulled apart and any worn pieces replaced? 1200 miles be due for a rebuild for sure..
__________________
2018 F-350 6.7 Platinum
2019 Axys RMK 850 155"
2016 Axys RMK 155"
2013 CVO Road Glide
2011 AMG C63 Sedan Sold
"Haywood, who's a convicted felon in the offseason.."
The Following User Says Thank You to G-Force For This Useful Post:
snoballssnoglory (01-27-2017)
  #5
Old 01-27-2017, 07:44 AM
rulonjj's Avatar
Default
I bought it private from a sponsored rider. It used to have a bd sidekick on it. Alpine supposedly had it running good and that's why I bought it. My dealer said the reeds also looked good. I'm taking the clutch apart today to see how it looks. We may end up replacing the wiring harness and the ecu. But we are trying all the small stuff, sensors, relays and capacitors first.
Even with how crappy it is running I love how this sled handles. It just keeps going when it should be stuck.
  #6
Old 01-30-2017, 08:09 AM
jhurkot jhurkot is offline
Currently: Not set.
jhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond reputejhurkot has a reputation beyond repute
Default
My sled was doing the exact same thing with reed pedals blown out on the PTO cylinder. They damaged the cylinder walls and polaris put in a new top end. How do your plugs look?Other possibility is injector but if your plug is wet and makes a spark i'd be leaning towards reeds or exhaust valve issue. While you're messing around it's probably not a bad idea to pull and clean all electrical connections and add a tiny bit of dielectric grease. When you are looking at the clutch check the rollers by pushing on them hard when you rotate them to feel for rough spots. Could also be a sacked out primary spring. Stock clutching should be 120/330 primary spring, 64g weights (probably too heavy for CO), 155/222 secondary spring, and straight 40 helix. Hope you get it sorted out!
2 out of 2 members found this post helpful. Rate this post: Yes | No
  #7
Old 01-30-2017, 01:37 PM
Murph's Avatar
Murph Murph is offline
Currently: Back in the mountains
Murph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond repute
Default
Quote:
Originally Posted by rulonjj View Post
I bought it private from a sponsored Polaris rider. It used to have a bd sidekick on it. Alpine supposedly had it running good and that's why I bought it. My dealer said the reeds also looked good. I'm taking the clutch apart today to see how it looks. We may end up replacing the wiring harness and the ecu. But we are trying all the small stuff, sensors, relays and capacitors first.
1200 Turbo miles with a "sponsored" rider at the controls... have you done a compression check, leak down, or pulled the cylinders to look at pistons and rings? When I tore down our two 2016 Axys, I found both cylinders out of spec and pistons were worn... @ 650 miles and 1200 miles AND they were stock with non-sponsored riders at the controls.
__________________
Missing Digit Motors-- Servicing your 2011-current ProRMKs in Truckee, CA
Truckee's source for BMFab,Camso Tracks, Indy Specialties, Lectron Carbs, Mountain Side Products, Mystik Oil, RAZE Motorsports, Speedcell and other fine snowmobile products
Speedcell Technologies-- Founding Member
Tahoe Nordic Search and Rescue-snowmobile team
Auburn Extreme Powersports--(530) 885-7105 My local Polaris Dealer
  #8
Old 01-31-2017, 10:45 AM
Timbre Timbre is offline
Currently: Let 'er SNOW!!
Timbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond reputeTimbre has a reputation beyond repute
Default
If i had a list of sleds to buy, and one that "used to have a turbo" was on it . . .that one would be a the very bottom of the list! Just sayin
  #9
Old 01-31-2017, 11:41 AM
rulonjj's Avatar
Default
Quote:
The joys of buying from a dishonest person. I didn't know it had a turbo until after I got it home. When I asked them if it had anything done to it they said it only had a can and alpine had just gone through it to make sure everything was good. Turns out, alpine hasn't touched this sled since the turbo was installed. I picked the sled up at night so I didn't see the hole in the tunnel til the next day.
  #10
Old 02-01-2017, 09:42 AM
Default
Wow! Huge Bummer! Unfortunately there are dishonest people everywhere.
It is a 2016 Axys, correct?
Wondering if a friend or dealer that has a good running sled would swap ECUs with you and let you take it for a rip to rule out that piece of the puzzle . . ?
Also, the dealer might "update" the fuel mapping in the ECU to the 2017 version.
You might give Carl's Cycle Sales in Boise ID (208.853.5550) a call and talk to the service department for any suggestions. They can't "diagnose" a sled over the phone obviously, but may have come across this same issue in the past and might have some helpful ideas or things to try. If the service dept is not too helpful, you might try talking to Jack (the owner) directly about this as well. He is a genius when it comes to these things. He is extremely busy and hard to get ahold of . . .just a fair warning
Good luck!
The Following User Says Thank You to Timbre For This Useful Post:
rulonjj (02-01-2017)
  #11
Old 02-01-2017, 10:04 AM
rulonjj's Avatar
Click Here to Register
  #12
Old 02-01-2017, 10:47 AM
  #13
Old 02-01-2017, 11:51 AM
Indy_500's Avatar
Garage
  #14
Old 02-01-2017, 04:05 PM
ullose272 ullose272 is offline
Currently: workin for the weekend
ullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond reputeullose272 has a reputation beyond repute
  #15
Old 04-05-2019, 07:59 PM
BrokeassSled BrokeassSled is offline
Currently: Not set.
Basic Member
BrokeassSled is an unknown quantity at this point
  #16
Old 04-14-2019, 05:56 PM
ripnit ripnit is offline
Currently: working my a$$ off to take time off this winter to RIDE
ripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Axys Assault vs Axys Pro Thread Starter — Wood Forum — Polaris: AXYS Replies — 11 Last Post — 12-30-2017 01:06 AM
Thread — Dilemma... 16 axys w Bd turbo or 17 axys 174 Thread Starter — Jimb Forum — Polaris: AXYS Replies — 6 Last Post — 09-18-2016 12:27 PM
Thread — Axys 163 vs. Axys 155 ??? Thread Starter — FatDogX Forum — Polaris: AXYS Replies — 44 Last Post — 04-12-2016 10:30 AM
Thread — Axys snowcheck V Axys pro Thread Starter — Hairdryr Forum — Polaris: AXYS Replies — 7 Last Post — 02-04-2016 08:21 PM
Thread — Pro RMK Axys tether installation video & Axys carbon windshield Thread Starter — Mxracer39 Forum — Polaris: AXYS Replies — 8 Last Post — 01-06-2016 02:20 PM
no new posts
