Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 02-11-2013, 07:28 PM
TRS's Avatar
TRS TRS is online now
Currently: 2019-2020 winter on the way
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
Thumbs up (SHORT VERSION) PRO RMK: DOO REMOTE BYPASS THERMOSTAT. PARTS LISTS AND INSTALLATION
Quote:
EDIT: mountainhorse...
This thread outlines all the parts needed to do this upgrade, feedback and installation photos... Please read it from the first page to get all details.
From an e-tec, stops the heat soak. Holds 109-111F
Sorry, I can't get the picture to flip.
Click image for larger version
Rate this post: Yes | No
  #2
Old 02-12-2013, 09:09 PM
TRS's Avatar
Default
BRP
1- 509000499 Thermo housing with internal thermostat
1- 509000372 3/4 x 1 barbed tee
Napa
4- power grip 42934
2- power grip 42925
1- 5/8 bypass cap 660-1696 1-8205 hose
1-7378 hose
Polaris
1- CT clamp 7080533
Washer for thermostat replacement 34mm OD, 27mm ID, 1mm thick
  #3
Old 03-10-2013, 11:53 AM
TRS's Avatar
Default
Quote:
Originally Posted by ditch1000 View Post
Once the heat soak is gone the kit should make the power that it's promised. Is that what you guys are seeing?? When I had mine loaded last week, when the motor would heat up (even in 2 1/2' of fresh powder) the power would fall off.
Can't wait to try it again this weekend with the new coolant bypass in place.
Lets not get this thread into something that it was not intended to be. I didn't claim or promise any HP gain. I was witnessing temp issues I thought could be addressed in a cheap, simple manner. I found a fix and passed it on to my Pro brothers. I could have put this kit together and sold it, but that was not my intent.
  #4
Old 03-12-2013, 02:55 PM
TRS's Avatar
Thumbs up PRO RMK: DOO REMOTE BYPASS THERMOSTAT (SHORT VERSION)
pictures of parts
ID:	203235   Click image for larger version
ID:	203236   Click image for larger version
The Following 2 Users Say Thank You to TRS For This Useful Post:
Newby2sleds (01-23-2014), Norway (03-29-2013)
  #5
Old 03-12-2013, 03:32 PM
TRS's Avatar
Default
Forgot the plug and bypass cap. The 8205 may work without the barbed fitting. Will know in an hour.
  #6
Old 03-12-2013, 04:30 PM
TRS's Avatar
Default
8205 works fine. Here is an install I just did. 20 min start to finish. Used powerclamps, same price as the CT clamps. Cleaner install.
ID:	203241   Click image for larger version
ID:	203242   Click image for larger version
ID:	203244   Click image for larger version
ID:	203245   Click image for larger version
The Following User Says Thank You to TRS For This Useful Post:
Bossman (01-29-2014)
  #7
Old 03-12-2013, 04:33 PM
TRS's Avatar
Default
I wish I could get them to flip. Must be that iphone thing.
ID:	203248   Click image for larger version
  #8
Old 03-12-2013, 05:36 PM
snobyrd snobyrd is offline
Currently: in memory of Johnny,JAN 23 2011
snobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond repute
Default
TRS , I c u used washers with a rubber gasket on it, is it just a T stat gutted or something u made?
  #9
Old 03-12-2013, 07:16 PM
TRS's Avatar
Default
Aluminum washer I made on the lathe. Same with the plug, made from delrin.
  #10
Old 03-21-2013, 10:43 AM
TRS's Avatar
  #11
Old 04-06-2013, 09:31 PM
TRS's Avatar
Click Here to Register
The Following 4 Users Say Thank You to TRS For This Useful Post:
mountainhorse (04-07-2013), Norway (04-07-2013), rab (02-15-2017), Solby (04-07-2013)
  #12
Old 05-06-2013, 08:54 AM
TRS's Avatar
The Following 5 Users Say Thank You to TRS For This Useful Post:
diamonddave (09-17-2013), dragonfire (05-06-2013), mountainhorse (05-06-2013), Norway (05-08-2013), wrang (05-13-2013)
  #13
Old 05-27-2013, 12:21 PM
TRS's Avatar
  #14
Old 07-10-2013, 04:34 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
  #15
Old 07-11-2013, 08:37 PM
TRS's Avatar
  #16
Old 09-21-2013, 08:41 PM
TRS's Avatar
  #17
Old 11-04-2013, 03:09 PM
LoudHandle LoudHandle is offline
Currently: I'd rather snowshoe than be caught on a SKIDOO! I'm not feminine / gay enough to ride SkiDoo either.
LoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond repute
  #18
Old 11-04-2013, 04:51 PM
Daltech's Avatar
Daltech Daltech is offline
Currently: Riding
Daltech has a reputation beyond reputeDaltech has a reputation beyond reputeDaltech has a reputation beyond reputeDaltech has a reputation beyond reputeDaltech has a reputation beyond reputeDaltech has a reputation beyond reputeDaltech has a reputation beyond reputeDaltech has a reputation beyond reputeDaltech has a reputation beyond reputeDaltech has a reputation beyond reputeDaltech has a reputation beyond repute
  #19
Old 11-25-2013, 04:43 PM
  #20
Old 01-22-2014, 10:03 PM
Greene Machine Greene Machine is offline
Currently: Kalispell MT
Basic Member
Greene Machine has a reputation beyond reputeGreene Machine has a reputation beyond reputeGreene Machine has a reputation beyond reputeGreene Machine has a reputation beyond reputeGreene Machine has a reputation beyond reputeGreene Machine has a reputation beyond reputeGreene Machine has a reputation beyond reputeGreene Machine has a reputation beyond reputeGreene Machine has a reputation beyond reputeGreene Machine has a reputation beyond reputeGreene Machine has a reputation beyond repute
  #21
Old 01-22-2014, 10:18 PM
Dartos's Avatar
Dartos Dartos is offline
Currently: Waiting
Dartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond reputeDartos has a reputation beyond repute
  #22
Old 01-23-2014, 02:36 AM
The Following User Says Thank You to mountainhorse For This Useful Post:
TRS (01-23-2014)
  #23
Old 01-23-2014, 03:09 AM
The Following 2 Users Say Thank You to LoudHandle For This Useful Post:
mountainhorse (01-23-2014), TRS (01-23-2014)
  #24
Old 01-23-2014, 09:26 AM
AgentRmk's Avatar
AgentRmk AgentRmk is offline
Currently: Working...to pay for mods...
AgentRmk has a reputation beyond reputeAgentRmk has a reputation beyond reputeAgentRmk has a reputation beyond reputeAgentRmk has a reputation beyond reputeAgentRmk has a reputation beyond reputeAgentRmk has a reputation beyond reputeAgentRmk has a reputation beyond reputeAgentRmk has a reputation beyond reputeAgentRmk has a reputation beyond reputeAgentRmk has a reputation beyond reputeAgentRmk has a reputation beyond repute
  #25
Old 01-23-2014, 12:35 PM
TRS's Avatar
mountainhorse (01-23-2014), wellfed777 (01-30-2014)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — BYPASS THERMOSTAT UPGRADE (PREVIOUSLY $28 upgrade) Thread Starter — TRS Forum — Polaris: Pro-Ride Replies — 280 Last Post — 01-17-2019 07:54 AM
Thread — Who is running the bypass on there thermostat? Thread Starter — the gman Forum — Snow bikes Replies — 8 Last Post — 11-03-2013 11:10 PM
Thread — PRO RMK Short Windshield For Sale Thread Starter — M7SLEDHEAD Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 5 Last Post — 08-13-2013 10:29 AM
Thread — Thermostat bypass questions Thread Starter — the gman Forum — Snow bikes Replies — 8 Last Post — 12-19-2012 10:58 PM
Thread — The new Nytro blew my mind!! short track version.. Thread Starter — GODEEP Forum — General Snowmobiling Replies — 9 Last Post — 12-18-2007 06:04 AM
no new posts
