Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 01-02-2011, 10:47 PM
sierraclimber's Avatar
sierraclimber sierraclimber is offline
Currently: More powder please
sierraclimber has a reputation beyond reputesierraclimber has a reputation beyond reputesierraclimber has a reputation beyond reputesierraclimber has a reputation beyond reputesierraclimber has a reputation beyond reputesierraclimber has a reputation beyond reputesierraclimber has a reputation beyond reputesierraclimber has a reputation beyond reputesierraclimber has a reputation beyond reputesierraclimber has a reputation beyond reputesierraclimber has a reputation beyond repute
Default 03 900 low rpm hesitation bog/high rpm loss
She's running goofy. Rough idle with a hesitation and bog on the low end. Mid range snappy as usual. Loss of top end rpms by about 1,000. Noticed a slight loss of high rpms the weekend before the low end bog appeared.
Plugs look good. Pulled on the power valve cables and they pull freely and snap back. I watched the servo and it does nothing if I blip the throttle wide open. But, after it comes back down to idle the servo rotates real quick and then goes back. Never watched the servo in action before so not sure how it is supposed to behave?
Threw half a tank of 91 in before I started having problems. Also filled my 2010 at the same time and it runs fine so the gas isn't bad. Could 91 make it run this poorly?
Any suggestions on what to check?
__________________
2016 Yeti 120" on KTM 540
2013 ProRMK 155" - PAR Head, Bikeman piston kit, SLP Can, Raptor Coils, MTNTK Blow Hole, ProMotion, 3" track
2012 ProClimb M8 Sno Pro 153" - MoFlow vents, Rasmussen steering upgrade, Skid plate, TLC brace from White Rad
2010 M8 SnoPro 162" - Mods, most everything accept a turbo.
2003 Cat 900 1m 151" -
Rate this post: Yes | No
  #2
Old 01-03-2011, 09:14 AM
Idcatman1's Avatar
Idcatman1 Idcatman1 is offline
Currently: Not set.
Idcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond repute
Default
My first thought on the low end rough idle and bog is a plugged pilot jet which would give you a hesitation when you hit the throttle. I think you are on the right track with the power valves for your problem on the top end. When you start the engine watch the servo, throttle up slowly and it should cycle once if things are working correctly. If it cycles three times that usually means something is not right and it will not open the valves when you are running. I would check the cables. Unhook them from the servo and see that the free length is the same. I have two different service manuals with two different figures as to what that length is supposed to be. I will try to look it up and post back. Your half tank of premium should not be causing what you are describing.
The Following User Says Thank You to Idcatman1 For This Useful Post:
sierraclimber (01-03-2011)
  #3
Old 01-03-2011, 11:25 AM
Default
Thanks a lot for the ideas. I will check everything later today. Great to have an idea of what the PV servo should be doing. My service manual says the length on the cables for a 900 should be 1.2 inches.
So is a servo "cycle" a quick down and back motion that takes about 1 second?
__________________
  #4
Old 01-03-2011, 09:43 PM
Idcatman1's Avatar
Currently: Not set.
Default
yes and that sounds right for the length of the cable also.
  #5
Old 01-06-2011, 01:32 AM
01polcat 01polcat is offline
Currently: Not set.
01polcat is an unknown quantity at this point
Default ?
What should the cable length be for my 04
  #6
Old 01-06-2011, 08:31 PM
snailbait's Avatar
snailbait snailbait is offline
Currently: IT'S FINALLY HERE!!!.....AND IT'S DEEEEEEP!
snailbait has a reputation beyond reputesnailbait has a reputation beyond reputesnailbait has a reputation beyond reputesnailbait has a reputation beyond reputesnailbait has a reputation beyond reputesnailbait has a reputation beyond reputesnailbait has a reputation beyond reputesnailbait has a reputation beyond reputesnailbait has a reputation beyond reputesnailbait has a reputation beyond reputesnailbait has a reputation beyond repute
Default
Make sure the spring or spider in the driven clutch is not broken. Have seen that cause similar issues that you describe.
I have an 03 that I just did the cables on...and the dealer told me 1.55..or 1 1/2 inches on the length of the cable. Only been out once, but she ran great.
Good luck,
Steve
  #7
Old 01-09-2011, 04:13 PM
fishtank fishtank is offline
Currently: Lovin the M Series!
Basic Member
fishtank has a reputation beyond reputefishtank has a reputation beyond reputefishtank has a reputation beyond reputefishtank has a reputation beyond reputefishtank has a reputation beyond reputefishtank has a reputation beyond reputefishtank has a reputation beyond reputefishtank has a reputation beyond reputefishtank has a reputation beyond reputefishtank has a reputation beyond reputefishtank has a reputation beyond repute
Default
I had the same issue with the same sled!! Turned out to be the throttle snow safety switch thingy. (im told not all throttles have them though)
Disconnected the kill switch and the problem went away.
  #8
Old 01-09-2011, 06:30 PM
Default
Interesting on the cable length. Here is what I have from the service manual.
900 cc range - 29.6 mm (1.17 in.) - 30.6 mm(1.20 in.) - 31.6 mm(1.24 in.)
The 700 however has close to the specs the dealer told you.
700 cc range - 36.15 mm(1.423 in.) - 38.15 mm(1.501 in.)
That is crazy about the throttle safety sensor and the fix is to disconnect the kill switch. I guess if it works don't knock it. My key broke off in the switch so if I disconnect the handle bar kill switch I won't be able turn her off!
Looks like I won't have time to work on her till next week but appreciate the ideas! I'll be looking at all possibilities.
__________________
  #9
Old 01-09-2011, 07:28 PM
Basic Member
Default
Heh, im the opposite, my kill switch got snapped off. We replaced it with a self tapping screw but its hard to pull the screw up with gloves on so my key is now my kill switch. :P I hope I dont go over the handlebars again and snap it off, could make the next trip interesting!!!
  #10
Old 01-10-2011, 09:15 AM
Idcatman3's Avatar
Idcatman3 Idcatman3 is online now
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
  #11
Old 01-10-2011, 10:30 AM
Arctic Thunder Arctic Thunder is offline
Currently: Not set.
Arctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond reputeArctic Thunder has a reputation beyond repute
Click Here to Register
  #12
Old 01-15-2011, 02:09 PM
Basic Member
  #13
Old 02-25-2011, 11:39 AM
  #14
Old 02-25-2011, 06:15 PM
Idcatman1's Avatar
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Turbo bog, high RPM Thread Starter — Holomis International Forum — Polaris: TURBO Replies — 42 Last Post — 01-11-2011 07:07 PM
Thread — 05 M7 High RPM Bog Thread Starter — 05M7 Forum — Arctic Cat: M Series Replies — 9 Last Post — 12-08-2010 01:46 PM
Thread — xp low rpm bog Thread Starter — brokenbones4 Forum — Ski-Doo Replies — 2 Last Post — 01-22-2010 11:14 PM
Thread — help high rpm bog and no tach Thread Starter — bc shredder Forum — Ski-Doo: REV Sleds Replies — 5 Last Post — 01-22-2010 06:58 PM
Thread — 800 high rpm bog Thread Starter — spook222 Forum — Polaris: GEN 2 Replies — 5 Last Post — 10-28-2009 05:49 PM
no new posts
