Upgrade to Premium
Reply
  #1
Old 05-04-2018, 11:44 AM
Daveferrier1 Daveferrier1 is offline
Currently: Not set.
Basic Member
Daveferrier1 is an unknown quantity at this point
Default Draining gas tank
Hi there,
This is probably a stupid question? I have a 2008 600 rmk and I'm looking to train the fuel tank. Can I drain the fuel line and is that tough? Or should just siphon the gas out? Thanks alot! - Dave
Rate this post: Yes | No
  #2
Old 05-04-2018, 01:27 PM
BeartoothBaron BeartoothBaron is online now
Currently: Not set.
BeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond repute
Default
One way to do it – at least with carbed sleds, not sure about EFI – is to disconnect the fuel line before the fuel pump and run a length of hose to your catch can, then use an air hose to put pressure in the fuel tank. That will drain the fuel line. You don't need (or want) much pressure; I think some people just use a blow chuck and seal off the filler neck with their hand. You could also modify a fuel cap or make some kind of plug to attach the air hose to, making sure you don't apply more than a few PSI.
Siphoning is another option, one I'd guess will leave a bit more fuel in the tank. It's very difficult to get the tank bone dry regardless. Depending on the tank, even taking it off and dumping it may not get it all out. I prefer to fill my tank with ethanol-free gas (probably most critical) and add fuel stabilizer before I store it. I've never had a problem doing that. The good gas will keep a long time provided it's not exposed to much moisture or open to the air. It also gives you the option of firing your sled up every month or so, which probably does more good than any amount of fogging, draining, etc. I try to do that with mine, but often forget or am gone for an extended period – still no issues though.
  #3
Old 05-04-2018, 03:22 PM
Currently: Not set.
Basic Member
Default Fuel drain
I have the carb model of the two, all black. Unfortunately I can't ad stabilizer because the engine has been fogged and what not. So I can't fire it up. Maybe a 1\4 of a tank of so in it.? Just got the sled last month. Do this is all new to me. It is in the garage for the summer.
  #4
Old 05-07-2018, 12:27 AM
Currently: Not set.
Default
Well, if it were me, I'd take however many cans of gas you think it'll take, add stabilizer to the cans, fill them, and top it off. You'd probably be just adding the recommended dose of stabilizer based on tank size and fill it with plain gas. The only time I'd say an additive won't mix in enough is if you just dump it in without adding gas, or if the tank is close to full. Adding stabilizer to the gas can, filling the can at the pump, and then filling the sled will give you the most thorough mixing. With a relatively empty tank though, it probably makes no difference.
It would be nice to run it long enough to get the stabilized gas through the fuel lines, though not necessary. What I like to do warm it up, then shut off the gas to burn up the fuel in the carbs and fuel pump. That's more of a "may help a little" thing though; probably the best way to avoid any potential issues is to pull the carbs when you're getting ready next season. Take the bowls off, spray them down with carb cleaner, and blow out all the passages. Maybe overkill for a sled that's you've owned a while and taken care of, but I'd recommend it for one that's new to you so you can be sure it's clean, and verify your jetting.
1 out of 1 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — WTB Gas tank for 08-11 m8/m1000 complete or bare tank Thread Starter — nebraska m8 Forum — WTB (Swapmeet) Replies — 1 Last Post — 01-09-2018 07:48 PM
Thread — Draining Fuel Tank Thread Starter — HouseCO Forum — Polaris: Pro-Ride Replies — 3 Last Post — 01-12-2012 02:40 PM
Thread — 2007 Dragon 700 pats for sale, gas tank, oil tank, etc. Thread Starter — Corey223 Forum — Fuels/Oils/Lubrication (Swapmeet) Replies — 1 Last Post — 10-17-2008 03:46 PM
Thread — 2007 Dragon parts. gas tank, oil tank, consol, airbox Thread Starter — Corey223 Forum — Chassis/Tunnel (Swapmeet) Replies — 1 Last Post — 10-17-2008 03:42 PM
Thread — 99 gen 2 parts oil tank, gas tank etc Thread Starter — sledbandit Forum — Fuels/Oils/Lubrication (Swapmeet) Replies — 6 Last Post — 02-02-2008 01:01 PM
no new posts
