Spill the beans bud....
You wrote a lot without really telling us anything.
I’m starting to trend with DDecker but I also want to give the Alpha more time because each ride I tweak somethings from settings to rider position. Then I change my mind again. The hardest thing for me is the track is so bad a$$ I don’t want to give it up. So I want to try hard to make the alpha work.
Here is my observations:
1. You do have to ride more forward when it gets technical. For a taller rider that can be awkward. Because you get in body positions that are harder to react to. Lowering the riser is not always the easiest for a tall rider. So I’m going to try getting the bars forward. I’m going to start with a 2” inch Rox riser on the bottom of the riser. Start there to see if that gets me enough space. The next option is a post forward kit but I just prefer the vert steering swing so don’t want to go there.
2. Shock settings are super critical and probably should be changed with changing snow conditions, especially in the skid. Last ride I found I maybe running to much pressure in my rear shock. I always leave my settings on 2. I was trenching out in spots I didn’t think I should be. After a stuck I thought what the heck, turned the rear shock to 1 and it made a big difference. I’m 220 without gear and running 145 in the rear shock. I’m going to drop that to 135 for the next ride and see if that works on setting 2. Maybe I’m wrong on this but I’m nervous running the rear shocks on postion 1 with the alpha rail. Seems like some of the damage to the rail was from bottoming out. Setting shocks is a “science” I just don’t fully understand yet so if you have found something that works, post it up. I did find when I put the shock in position 1 I had to be a lot more forward in climbs.
See if a few small changes can help. Right now I do think a twin rail is better when things get super technical and the traction/bit isn’t as good in harder snow. But damn the Alpha is a fun sled to ride.
