A
you guys notice the new yamicat doesnt have a TCL???? its braced from the secondary to the cross frame member
Looks like they went all out on the belt guard again..
http://www.arcticinsider.com/Article/Arctic-Cat-Yamaha-Speculation--Reading-Between-the-Lines
You can see the engine motor mounts in the above link.
There is no TCL on this engine. It also sits way too high, you could fit a small child underneath it.
I'm sure this will be one of those "subject to change" things that happen before final production
you want a lower center of gravity, the lower the weight the easier it is to lay over and the less it wants to counter roll (go the other way when you plane out)
the lower center of gravity in the M series is one of the reasons its such a predictable sled on its side, and is so easy to flick around.
-Aksnopro
Cat has been working on getting the motor down and back for some time.
It's the reason for the laydown motor.
It's the reason they angled the cylinder base on the ZRT600's in the mid 90's.
This is Cat's project, Yamaha approves and signs off.
My bet you will see that motor a lot lower by the time it comes to production.
They can easily redo that Exhaust manifold
Question I have is will we see a TCL on 2014 Cat's?
Coming from someone who has mounted a yamaha motor in a chassis that was not designed for it. I know that it is not as easy to get the motor down and back. Th stater is under there. . and the motor mounts are there to and are cast into the block. I highly doubt you will see motor position change from now to production. They were probably able to move the motor a inch to the rear of the chassis with mounting it higher and there were more benefits of being back farther than having to be 2 inchs forward and 2 inch lower.
I can see too low a CG in a mountain sled to be an issue.
Theres a fine line to balance it on it's side. Too low and it will want to come back down. Too high and it will fall on it's side.
Boat manufactures study this big time too.
These are trails sleds, lower the better=flater
When I went into the Navy I had not idea what I wanted to do. I did know I wanted to go into Engineerng.
I got out as a Boiler Technician and 24 years later still boil water for a living.
Had I known then what I know now I would have went into the service but leaned torward Mechnical Engineering.
I think it would be a blast to work R&D at Arctic Cat
