Wiring Diagram
C
Looking for a wiring diagram for an XP
i'm adding a vision X light to my sled, am curius which wire to tap into. looking to tap into a wire right at the switch for the high beems. which (color) wire contraols the high beems
thanks Mike
L
May 15, 2009
453
60
On the 08's the wire coming out of the switch and going to the bulbs is gray.
Another thought, is that you could tap into the wire at the bulbs.
TWARD700
77
Seattle WA
If your removing you stock head light then all you need to do is run two wires to where your putting the lights to the plug for the stock headlight and use two male spade connectors and plug them in to the plug for the stock headlights. If your not removing the stock lightss than splice in the the low beam or high beam wire at the head light and you can get your power from there. I did this on my sled last year.
