Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 11-22-2016, 12:19 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Lightbulb FIRST START OF THE SEASON?? TAKE 5 MIN AND DO AN EASY FLUSH OF THE FUEL LINES FIRST.
If your sled has been sitting since last season, with the old gas in it.
If you have not fired up your sled yet for the season...Best to drain ALL the old gas out... ALL of it.. and fill with fresh... with your fuel system cleaner of choice and some pre-mix oil... and, without starting the sled.... run the fuel pump on prime mode for about 5 minutes to flush the, pickup, pump, fuel lines, fuel rail of any varnish or sludge buildup.
The moment you fire the sled... what ever is in the lines... be it fresh gas or old gas... will be pushed through the injectors.
Priming the system leaves the injectors closed... but circulates fuel through the entire fuel system.... best to start off the season as fresh as possible. If you run the prime for a while... the first fuel the injectors will see will be as clean as possible.
Especially since the AXYS-Mtn sleds don't have any fuel filter other than the fuel-pump pickup 'sock'
__________________
Signature:
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to mountainhorse For This Useful Post:
2007dragonman (11-22-2016)
  #2
Old 11-22-2016, 01:55 PM
mountaincat 800's Avatar
mountaincat 800 mountaincat 800 is online now
Currently: Not set.
mountaincat 800 has a reputation beyond reputemountaincat 800 has a reputation beyond reputemountaincat 800 has a reputation beyond reputemountaincat 800 has a reputation beyond reputemountaincat 800 has a reputation beyond reputemountaincat 800 has a reputation beyond reputemountaincat 800 has a reputation beyond reputemountaincat 800 has a reputation beyond reputemountaincat 800 has a reputation beyond reputemountaincat 800 has a reputation beyond reputemountaincat 800 has a reputation beyond repute
Default
Is it really THAT important to you that you have to post this twice? I know I'm a little OCD but you?
__________________
'17 M8000 Limited, '17 Axys Pro RMK 800 '15 Pro RMK 800 '14 Pro RMK 800 '12 Pro RMK 800 '10 M8 Sno Pro '09 M8 Limited '07 Avalanche Survivor '06 M7 153 LE '04 King Cat '03.5 Mountain Cat 900 '01 Mountain Cat 800 '96 ZRT600 '91 EXT Special '87 Eltigre' 5000 '81 Eltigre' 5000
  #3
Old 11-22-2016, 02:12 PM
sumtinwong sumtinwong is offline
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
Default
how do u prime the sled??
  #4
Old 11-22-2016, 03:28 PM
Default
One thread in the AXYS section ... one in the ProRide section.
Quote:
__________________
Signature:
  #5
Old 11-22-2016, 03:34 PM
Default
Quote:
Good post from Volcano Buster... THX !
Quote:
Originally Posted by volcano buster View Post
In front of the belt cover area in the side of the belly pan are a couple connectors that don't go to anything. There is a dual wire connector that can be jumped to power the in-tank fuel pump. In the photo it is the furthest white connector to the right.
I use a high output 12v transformer that I wired a connector onto that I had from some other demolition project. It will run the pump until you are happy with the amount of circulation. Don't run the pump dry.
__________________
Signature:
The Following 2 Users Say Thank You to mountainhorse For This Useful Post:
Nooby (11-22-2016), sumtinwong (11-24-2016)
  #6
Old 11-23-2016, 05:09 AM
glowa glowa is offline
Currently: Not set.
glowa has a reputation beyond reputeglowa has a reputation beyond reputeglowa has a reputation beyond reputeglowa has a reputation beyond reputeglowa has a reputation beyond reputeglowa has a reputation beyond reputeglowa has a reputation beyond reputeglowa has a reputation beyond reputeglowa has a reputation beyond reputeglowa has a reputation beyond reputeglowa has a reputation beyond repute
Default
MH what is 12VDC in english? is this enough to use a 12V battery?
  #7
Old 11-23-2016, 08:07 AM
Reg2view Reg2view is offline
Currently: Not set.
Reg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond reputeReg2view has a reputation beyond repute
Default
Quote:
Yes. 12 volt DC, which a sled starter battery will provide.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Reg2view For This Useful Post:
mountainhorse (11-23-2016)
  #8
Old 11-23-2016, 11:11 AM
beamslayer's Avatar
beamslayer beamslayer is offline
Currently: just another day in paradise
beamslayer has a reputation beyond reputebeamslayer has a reputation beyond reputebeamslayer has a reputation beyond reputebeamslayer has a reputation beyond reputebeamslayer has a reputation beyond reputebeamslayer has a reputation beyond reputebeamslayer has a reputation beyond reputebeamslayer has a reputation beyond reputebeamslayer has a reputation beyond reputebeamslayer has a reputation beyond reputebeamslayer has a reputation beyond repute
Default
So you all don't start your sled once a month and let it get up to temp , just to smell the it ?
__________________
11 Pro Assault
The Following User Says Thank You to beamslayer For This Useful Post:
Nooby (08-11-2018)
  #9
Old 11-23-2016, 11:39 AM
Madtown's Avatar
Madtown Madtown is offline
Currently: Riding a AXYS RMK
Madtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond reputeMadtown has a reputation beyond repute
Default
Quote:
I know I do. Heard it helps oil internal engine parts from rusting as well.
  #10
Old 11-23-2016, 11:45 AM
Default
Yep... 12 Volts Direct Current
DC=Direct Current.
You don't necessarily need the mating connector... some wire stripped bare and inserted into the connector will suffice in a pinch.. make sure that brown is the negative wire. IMO, best to put the wires into the connector and make the connection at the battery/power-supply you are using.
I prefer to use a battery, IMO, don't use a battery charger as most don't have a stable output or are too small ('tenders')
The mating connector, for those that want to know:
Molex, 03-06-2023 connector housing , 60619-1 pins
Wire colors into the pin are
Ground (-) Brown w/yellow stripe
Positive (+) Red
__________________
Signature:
Sage Crusher (11-23-2016), volcano buster (11-23-2016)
  #11
Old 11-23-2016, 11:49 AM
Click Here to Register
Nooby (08-11-2018)
  #12
Old 11-23-2016, 02:31 PM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is offline
Currently: easing into Winter......
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
The Following User Says Thank You to Sage Crusher For This Useful Post:
mountainhorse (11-28-2016)
  #13
Old 11-24-2016, 02:18 AM
Currently: Not set.
Basic Member
The Following User Says Thank You to sumtinwong For This Useful Post:
  #14
Old 11-26-2016, 12:45 PM
Zanne81 Zanne81 is offline
Currently: Not set.
Basic Member
Zanne81 has a reputation beyond reputeZanne81 has a reputation beyond reputeZanne81 has a reputation beyond reputeZanne81 has a reputation beyond reputeZanne81 has a reputation beyond reputeZanne81 has a reputation beyond reputeZanne81 has a reputation beyond reputeZanne81 has a reputation beyond reputeZanne81 has a reputation beyond reputeZanne81 has a reputation beyond reputeZanne81 has a reputation beyond repute
  #15
Old 11-27-2016, 05:25 AM
Currently: Not set.
Basic Member
  #16
Old 11-27-2016, 10:20 PM
Jimb Jimb is offline
Currently: Not set.
Jimb has a reputation beyond reputeJimb has a reputation beyond reputeJimb has a reputation beyond reputeJimb has a reputation beyond reputeJimb has a reputation beyond reputeJimb has a reputation beyond reputeJimb has a reputation beyond reputeJimb has a reputation beyond reputeJimb has a reputation beyond reputeJimb has a reputation beyond reputeJimb has a reputation beyond repute
The Following User Says Thank You to Jimb For This Useful Post:
  #17
Old 11-28-2016, 12:54 PM
  #18
Old 11-28-2016, 01:05 PM
  #19
Old 12-19-2017, 08:24 PM
mountainhorse (12-19-2017)
  #20
Old 12-19-2017, 08:32 PM
sledsrock sledsrock is offline
Currently: SUMMER SUCKS!
sledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond repute
  #21
Old 12-19-2017, 09:31 PM
  #22
Old 12-19-2017, 09:35 PM
  #23
Old 07-07-2018, 02:52 PM
Sage Crusher (07-30-2018)
  #24
Old 07-30-2018, 12:46 PM
sledcaddie sledcaddie is offline
Currently: Not set.
sledcaddie has a reputation beyond reputesledcaddie has a reputation beyond reputesledcaddie has a reputation beyond reputesledcaddie has a reputation beyond reputesledcaddie has a reputation beyond reputesledcaddie has a reputation beyond reputesledcaddie has a reputation beyond reputesledcaddie has a reputation beyond reputesledcaddie has a reputation beyond reputesledcaddie has a reputation beyond reputesledcaddie has a reputation beyond repute
  #25
Old 07-30-2018, 02:58 PM
BeartoothBaron BeartoothBaron is online now
Currently: Not set.
BeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond repute
The Following User Says Thank You to BeartoothBaron For This Useful Post:
sledcaddie (08-01-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — FIRST START OF THE SEASON?? TAKE 5 MIN AND DO AN EASY FLUSH OF THE FUEL LINES FIRST. Thread Starter — mountainhorse Forum — Polaris: Pro-Ride Replies — 4 Last Post — 12-21-2016 10:31 PM
Thread — How are your fuel lines in the tank?? Thread Starter — lognomore Forum — Polaris: IQ Replies — 37 Last Post — 01-25-2012 08:17 PM
Thread — Easy Start the best $400 I have Spent!! Thread Starter — savagecanuck Forum — Polaris Replies — 20 Last Post — 02-24-2009 12:16 PM
Thread — how to get water out of fuel lines? Thread Starter — guidoxpress Forum — Polaris Replies — 4 Last Post — 01-28-2009 09:03 AM
Thread — fuel lines Thread Starter — KAWGRN Forum — Polaris Replies — 6 Last Post — 10-27-2008 01:00 PM
