Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 01-01-2019, 12:40 AM
Octanee Octanee is online now
Currently: Not set.
Octanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond repute
Default Det issues continue.... Tried everything it seems! 11 pro
Hey guys, so some may remember my troubles with my sled, and it still continues. no matter what I've done I keep getting det thrown, usually happens when on off the throttle, like sidehilling in powder or climbing. I ran Race gas, 100% av gas, threw in a 3 degree timing key, swapped tps, new tps, swapped exhaust sensor, swapped knock sensor. Engines rebuilt, checked and repaired my exhaust mount. Swapped. Factory fuel injectors, turbo injectors good, fuel pumps tested, air fuel is always good in boost, fuel filters new and Has never helped. At 6500 feet running low boost of ~4 psi which should be almost like running stock at sea level in theory.
Got the boost it xic box.
It was mentioned that maybe I'm rich, so I started to lean the sled out and it does run better and gets much more crisp and responsive, when I watch my air fuel gauge I cannot see anything that stands out, no big lean puffs of air, seems to be just fine when it Throws the code. Had one pull on the trail where i was 11.5:1 and as soon as I let off the throttle it threw the code. Again low boost high octane Fuel.
Seriously thinking there's something else setting this off somehow Ecm?? I had padded Anything I could see or Think of that could rattle causing an issue.
I talk with others selling their sleds with same turbo setup and said it's the Best turbo sled they've had.... But here I am banging my head against the wall,
Last winter I took the knock sensor off, 2 weeks ago I replaced My pistons because I was Concerned however looking at them I cannot see at all any detonation damage or Chipping on top, really starting to believe its a false set code.
Rate this post: Yes | No
  #2
Old 01-01-2019, 02:10 AM
kgra kgra is offline
Currently: Not set.
kgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond repute
Default
With that amount of boost have you tried 91 octane with no race fuel? Too much octane is not better. Not saying it’s your issue but slow burn fuels and not enough timing can cause excess heat in exhaust, on exh side of piston, on power valve, etc since the burn is happening too long which can trigger knock sensor very easily getting back into throttle when it is often on the lean side of things cause aux injectors usually only kick in once boost is sensed.
Anything that can cause a rattle or knock from flexing or twisting can sometimes trigger knock sensor.
How does it idle? What rpm?
Do your spark plugs ever loosen off? It is common if you are getting det.
When you checked your pistons did you measure piston skirt to cyl wall clearance?
Is there any previous damage to inside of cylinder head?
  #3
Old 01-01-2019, 02:34 AM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Blew up the R6 TS LT andbuilding the ZX6R 636
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
I had constant issues with my 2011 wiring harness.
Parting it out is the best thing to do to a 2011 pro.
__________________
Try again
  #4
Old 01-01-2019, 10:55 AM
Currently: Not set.
Default
I'm currently running 94 octane now, I also tried turning up the boost to see if it did anything and it made no difference either, I had the issue before the rebuild/s and before my timing key, everything I've done so far has not been the issue or the fix, had the sled apart many times and wiring harness moved around and still has not changed anything. I've played with the fuel setpoint, as well as the accel pump because yes I was thinking maybe its going lean when I get on the throttle again, it made no difference, In fact seemed to make it almost worse (maybe) hard to say, I also tried the throttle cut and nope it got big gulps of air so its not too rich when letting on and off the throttle.
It idles great, about ~2000 rpm or so, 1900 ish. spark plugs never loosen off, have had spark plug cap issues but thats resolved now. And this last go around I never measured the pistons exactly, I did compare the piston to cyl clearance between the new and old pistons and they were the same with a feeler gauge however I do not recall the measurement.
I hear you, I feel so defeated so far by the thing, but no electrical issues yet.
  #5
Old 01-01-2019, 11:00 AM
TRS's Avatar
TRS TRS is online now
Currently: Waiting for winter
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
Default
Did you replace the plug wires?
How about your MAP sensor?
The Following User Says Thank You to TRS For This Useful Post:
Sheetmetalfab (01-01-2019)
  #6
Old 01-01-2019, 11:01 AM
die hard poo's Avatar
die hard poo die hard poo is offline
Currently: Waitin' for snow...
die hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond reputedie hard poo has a reputation beyond repute
Default
Maybe its over-revving? My old pros would do throw a det code if it over-revved. Also maybe try and put a new det sensor in? Or just say screw it and remove the det sensor and run extra octane and call it a day. Up to you lol
__________________
16-AXYS PRO RMK 800 155 3"-
17-SUMMIT X 850 154 3"-
  #7
Old 01-01-2019, 11:59 AM
Default
I had the same det issues and traced several of them to the wiring harness.
(Completely hidden in the sheath)
I’d say you do have an electrical problem.........
Sent from my iPhone using Tapatalk Pro
__________________
Try again
  #8
Old 01-01-2019, 12:23 PM
Currently: Not set.
Default
Plug wires stock, map sensor is stock and placed in intake tube to my turbo.
Quote:
It deff could be over revving, the gauge reads so slow but I do remember even at 4psi at elevation rpm spikes of 8300 or so on the gauge. Im running IIRC the mtntk recommended clutching, red primary spring, I even welded my weights to get them heavier, but In hindsight I should of went to a lighter finish spring. I do have a few spare springs so I'll have to look at them and maybe throw one in.
What did you find in yours and where? I appreciate the feedback everybody! So far a few things I have over looked.
  #9
Old 01-01-2019, 12:44 PM
Default
Found wires with crumbled insulation inside the sheath.
(Crappy aluminum wire)
Also some wires had breaks inside the insulation that weren’t visible.
Unwind the entire harness to inspect every wire. (Or swap it out with a new / known good one..........
Worth trying plug wires, map sensor swaps for sure.
Bringing the max rpm down is usually a good test also. (If I ever saw 8300 on my 11’ gauge usually it was very close to overev-det.
__________________
Try again
  #10
Old 01-01-2019, 01:22 PM
Currently: Not set.
  #11
Old 01-01-2019, 03:10 PM
Currently: Not set.
Click Here to Register
  #12
Old 01-01-2019, 03:22 PM
Currently: Not set.
  #13
Old 01-01-2019, 05:03 PM
Currently: Not set.
  #14
Old 01-01-2019, 07:10 PM
Currently: Not set.
  #15
Old 01-01-2019, 07:28 PM
Currently: Not set.
  #16
Old 01-02-2019, 10:23 PM
Currently: Not set.
  #17
Old 01-02-2019, 11:35 PM
mt.sledder mt.sledder is offline
Currently: Silber Dealer
mt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond reputemt.sledder has a reputation beyond repute
The Following User Says Thank You to mt.sledder For This Useful Post:
Sheetmetalfab (01-03-2019)
  #18
Old 01-03-2019, 08:20 AM
diamonddave's Avatar
diamonddave diamonddave is online now
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
The Following 2 Users Say Thank You to diamonddave For This Useful Post:
cascadesnowjunky (01-05-2019), Sheetmetalfab (01-03-2019)
  #19
Old 01-03-2019, 11:53 PM
Currently: Not set.
  #20
Old 01-04-2019, 03:16 PM
WAsledder WAsledder is offline
Currently: Not set.
WAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond reputeWAsledder has a reputation beyond repute
  #21
Old 01-04-2019, 09:36 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
  #22
Old 01-04-2019, 11:29 PM
Currently: Not set.
  #23
Old 01-05-2019, 07:05 PM
Scott's Avatar
Garage
  #24
Old 01-05-2019, 08:24 PM
Currently: Not set.
  #25
Old 01-05-2019, 09:02 PM
Scott's Avatar
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Dragon det and low idle issues Thread Starter — sledmanhof Forum — Polaris: IQ Replies — 11 Last Post — 02-24-2018 12:49 PM
Thread — DET issues 2015 pro 800 Thread Starter — PSI 800 Forum — Polaris: Pro-Ride Replies — 17 Last Post — 09-25-2017 10:59 PM
Thread — DET issues on turbo pro Thread Starter — fullboredragon Forum — Polaris: Pro-Ride Replies — 10 Last Post — 01-05-2014 11:03 AM
Thread — Det issues !?!? Stumped Thread Starter — Kyle91rs Forum — Arctic Cat: TURBO Replies — 10 Last Post — 12-18-2013 02:50 PM
Thread — ANYONE HAVE THERE DET SENSOR GO OFF? OR TPS ISSUES? Thread Starter — tylbz Forum — Polaris: Pro-Ride Replies — 13 Last Post — 01-20-2012 10:47 PM
no new posts
