Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 12-09-2018, 06:27 PM
Ace Freely Ace Freely is offline
Currently: The problem with common sence, is that it isn't that common!
Ace Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond reputeAce Freely has a reputation beyond repute
Default Clutch Arms....ZRP vs SLP
Anyone used either of these? Thoughts? Noticable difference over stock?
Ace
https://www.zollingerracingproducts....stable-weights
https://www.startinglineproducts.com...r-ski-doo.html
Rate this post: Yes | No
  #2
Old 12-09-2018, 07:30 PM
sledhead_24_7's Avatar
sledhead_24_7 sledhead_24_7 is offline
Currently: pow hunting on the 850
sledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond repute
Default
Both are noticeable compared to stock, as well as different from each other. I have ran both.
__________________
2019 Summit X 850 175X3"
The Following User Says Thank You to sledhead_24_7 For This Useful Post:
Ace Freely (12-09-2018)
  #3
Old 12-09-2018, 08:46 PM
slinky slinky is offline
Currently: Not set.
Basic Member
slinky slinky slinky slinky slinky slinky slinky slinky slinky slinky slinky
Default
interested in some hands on knowledge as well
The Following User Says Thank You to slinky For This Useful Post:
  #4
Old 12-09-2018, 09:01 PM
live2beel live2beel is online now
Currently: Not set.
live2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond repute
Talking
Quote:
So which ones will you leave in?
The Following User Says Thank You to live2beel For This Useful Post:
  #5
Default
...and what did you leave in? Did you notice less heat? Blow any belts?
Ace
  #6
Old 12-09-2018, 09:06 PM
norsepeak norsepeak is online now
Currently: drinking, wishing for snow!
Basic Member
norsepeak has a reputation beyond reputenorsepeak has a reputation beyond reputenorsepeak has a reputation beyond reputenorsepeak has a reputation beyond reputenorsepeak has a reputation beyond reputenorsepeak has a reputation beyond reputenorsepeak has a reputation beyond reputenorsepeak has a reputation beyond reputenorsepeak has a reputation beyond reputenorsepeak has a reputation beyond reputenorsepeak has a reputation beyond repute
Default
I just got the MDS clutch arms. He's local to me and I've heard good things about his setup, so gonna try them.
The Following 4 Users Say Thank You to norsepeak For This Useful Post:
Ace Freely (12-09-2018), donbrown (12-10-2018), sledhead_24_7 (12-09-2018), winter brew (01-14-2019)
  #7
Old 12-09-2018, 09:28 PM
The SLP’s I need more time on. But at the moment they feel solid from bottom to top. Possibly a bit less bottom end ”snap”from a start. Most likely a tuning thing. But they do continue to pull through the power band. Easy to add or remove weight. This is on my 2019 Summit. Looking promising though. Looking forward to more time on the SLP weights. Engagement is around 3000-3200 rpm.
ZRP also work well, maintain RPM well. Once adjusted RPM does not move from 5,000ft to 10,000. The bottom end “snap” is as good or better than stock. Engagement can be set up to be nice and low or higher depending on preferences. Only down fall is the weights have to come out to add or remove. But once properly set, you never touch the clutch. Ran these on my 17 and 18 Summits. Not the 2019 yet. Belt heat on these sleds did not change with any clutch parts. Only prolonged the inevitable explosion of a belt. The ZRP was the best of what I’ve tried till this season, will see as we get into the season more.
Stock clickers are not needed, so no real worries about loosing them.
Side note: I blew lots and lots of belts on both my 17 and 18. No clutch parts made that stop. Hence the reason Skidoo has the 2019 updates/improved clutch ventilation etc. this year. The G4 is a excellent sled, however ridden hard in the deep the bad motor mounting rears up and bites back. Clutch parts gain performance... and for most probably better belt life, just not everyone (me) unfortunately.
__________________
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 8 Users Say Thank You to sledhead_24_7 For This Useful Post:
Ace Freely (12-09-2018), Blk88GT (12-10-2018), donbrown (12-10-2018), live2beel (12-09-2018), LPIdaho (12-13-2018), Matte Murder (01-13-2019), MountainTrashCat (01-13-2019), rulonjj (12-10-2018)
  #8
Old 12-09-2018, 10:01 PM
NoSoup4U NoSoup4U is offline
Currently: Not set.
NoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond repute
Default
I have an 18 175 and ran the ZRP weights with stock helix and a lighter primary and stiffer secondary spring all last year. Less clutch heat, smother engagement and more consistent RPM than the stock set up. Ability to add weight to the tip, belly or heel is a plus. No increase in track speed over stock on a steep powder climb. Better top end pull across the meadow or down the trail at speeds over 50 MPH. Only downside is you have to remove the weights to make adjustments. With the Goodwin Performance tool that was no problem, probably took 10 minutes from start to finish.
This year I’m running a clutch kit from ibackshift.com, don’t have many miles yet but so far seeing little difference from my setup from last year. It uses the stock arms, custom helix and pin set, softer primary and stiffer secondary.
To be honest, I think if you use the stock arms and helix with a softer primary (stock primary on a 19 is perfect) and stiffer secondary spring (stock low altitude secondary spring works great) and get a pin weight set to dial in the RPM to 7950 that you will pretty much match the performance of any of the clutch kits out there.
FWIW, I’m also running the SLP Magnum Force weights in my Axys. They work well, but aside from easy adjustability I don’t think they perform any better than Polaris 10 series weight.
Haven’t found any “mystical-magical“ qualities with either the ZRP or SLP weights. The work well, but switching to them won’t be that special sauce that will make your sled out perform your buddies sled.
The Following 7 Users Say Thank You to NoSoup4U For This Useful Post:
Ace Freely (12-09-2018), Blk88GT (12-10-2018), donbrown (12-10-2018), justinkredible56 (12-09-2018), live2beel (12-09-2018), Matte Murder (01-13-2019), sledhead_24_7 (12-09-2018)
  #9
Old 12-09-2018, 10:29 PM
Default
Quote:
E Burg! What's his kit cost?
Ace
  #10
Old 12-09-2018, 10:36 PM
Basic Member
Default
yeah, from Eburg. I think it's $240...comes with adjustable weights and a new primary spring. I've heard really good things, and he tests right in my back yard so...thought I'd give it a shot even though I haven't had belt issues.
  #11
Old 12-09-2018, 10:43 PM
ak ak is online now
Currently: Nothing
ak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to ak For This Useful Post:
  #12
Old 12-10-2018, 02:33 AM
donbrown's Avatar
donbrown donbrown is offline
Currently: Let it snow !!!
donbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond repute
The Following User Says Thank You to donbrown For This Useful Post:
PaulAnd (12-10-2018)
  #13
Old 12-10-2018, 08:18 AM
  #14
Old 12-10-2018, 10:06 AM
PaulAnd's Avatar
PaulAnd PaulAnd is offline
Currently: gen4 now please
PaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond reputePaulAnd has a reputation beyond repute
  #15
Old 12-10-2018, 01:47 PM
  #16
Old 12-10-2018, 01:57 PM
  #17
Old 12-10-2018, 02:51 PM
Inthe8s Inthe8s is online now
Currently: Not set.
Basic Member
Inthe8s has a reputation beyond reputeInthe8s has a reputation beyond reputeInthe8s has a reputation beyond reputeInthe8s has a reputation beyond reputeInthe8s has a reputation beyond reputeInthe8s has a reputation beyond reputeInthe8s has a reputation beyond reputeInthe8s has a reputation beyond reputeInthe8s has a reputation beyond reputeInthe8s has a reputation beyond reputeInthe8s has a reputation beyond repute
The Following User Says Thank You to Inthe8s For This Useful Post:
sledhead_24_7 (12-10-2018)
  #18
Old 12-10-2018, 03:06 PM
  #19
Old 12-10-2018, 07:40 PM
  #20
Old 12-10-2018, 07:44 PM
  #21
Old 12-10-2018, 08:10 PM
  #22
Old 12-10-2018, 09:51 PM
kanedog kanedog is online now
Currently: Undefeated Mountain Clutching Champ of the World!
kanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond repute
Garage
The Following 6 Users Say Thank You to kanedog For This Useful Post:
Ace Freely (12-10-2018), justinkredible56 (12-11-2018), Matte Murder (01-13-2019), MountainTrashCat (01-13-2019), PaulAnd (12-10-2018), WestWAsleder (12-10-2018)
  #23
Old 01-13-2019, 12:57 PM
  #24
Old 01-13-2019, 01:09 PM
  #25
Old 01-13-2019, 06:31 PM
Basic Member
The Following User Says Thank You to norsepeak For This Useful Post:
Ace Freely (01-13-2019)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Polaris Axys ZRP 36in A-Arms Thread Starter — homeboy Forum — Suspension/Shocks (Swapmeet) Replies — 2 Last Post — 09-29-2018 02:26 PM
Thread — ZRP cam arms Thread Starter — mtncat Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 01-18-2018 11:58 AM
Thread — ZRP billet clutch cover Thread Starter — bgraff1 Forum — Arctic Cat: Proclimb M Replies — 5 Last Post — 12-02-2017 08:07 AM
Thread — Zrp titanium clutch weight pins Thread Starter — ak Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 2 Last Post — 04-12-2017 11:53 PM
Thread — 2001 800 mxz clutch arms///tra arms? Thread Starter — dyllyn Forum — Ski-Doo Replies — 2 Last Post — 12-08-2008 01:29 AM
no new posts
