Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 12-05-2018, 09:17 PM
PrestigeMind PrestigeMind is offline
Currently: Not set.
Basic Member
PrestigeMind is an unknown quantity at this point
Default Air in coolant when warmed up 2015 pro rnk 800 turbo
This is my first post hello everyone. I appreciate any help I can receive here.
Here is the issue.
2015 My Polaris pro 800 163 turbo
Air is bubbling in coolant tank only when sled is heated up to 120 the point on the thermostat opening.
If you go to open the coolant with the sled cold air rushes out and the coolant bubbles.
Now I have checked all the hoses and clamps could this be a bad radiator cap ? I don't think it's a bad gasket or o ring as it only bubbles when thermostat opens and high rev. Not all the time.
What can cause air to lock into the reservoir?
I have ordered a new cap but I'm super confused on this one.
Rate this post: Yes | No
  #2
Old 12-24-2018, 01:20 PM
PSI 800 PSI 800 is offline
Currently: waiting to tear up the mtns
Basic Member
PSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond repute
Default
sounds to me like a cylinder head o-ring is shot.
  #3
Old 12-24-2018, 02:04 PM
diamonddave's Avatar
diamonddave diamonddave is online now
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
Default
Maybe but have you tried cracking the bleeder screw on top of the Thermostat housing?
Start sled cold, Crack the bleeder screw (5/16"/8mm (6) point socket on a long 1/4" drive extension) with the front of the sled elevated some. Close when you get no air/full coolant to come out. Probably get some air.
Wait for engine to warm while maintaining roughly a 1/2 coolant reservoir. Leave cap off during this.
Wait for engine to warm up and thermostat to open (usually 128 degrees), then crack bleeder again. You want to see no air and steady stream of coolant. Once you have no air/full coolant, close bleeder, top off coolant and reinstall cap.
1 out of 1 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Tags
800, bubbles, coolant, pro
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2015 Pro RMK 800 LE with Aerocharger Turbo Thread Starter — jtt454 Forum — Polaris (Swapmeet) Replies — 5 Last Post — 12-28-2017 01:42 PM
Thread — 2015 Polaris Pro 800 Turbo For Sale Thread Starter — arrkay Forum — Polaris (Swapmeet) Replies — 0 Last Post — 01-10-2017 12:48 PM
Thread — 2015 Pro RMK 800 with Aerocharger Turbo Thread Starter — jtt454 Forum — Polaris (Swapmeet) Replies — 1 Last Post — 11-30-2016 11:50 AM
Thread — 2015 Pro 800 Turbo $10500 Thread Starter — ccclark Forum — Polaris (Swapmeet) Replies — 0 Last Post — 09-20-2016 09:19 PM
Thread — 2002 800 rnk snowcheck $3500 Thread Starter — corpeleven Forum — Polaris (Swapmeet) Replies — 2 Last Post — 10-12-2008 07:58 PM
no new posts
