Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 11-28-2018, 06:54 PM
cdebodt44 cdebodt44 is online now
Currently: Not set.
cdebodt44 has a reputation beyond reputecdebodt44 has a reputation beyond reputecdebodt44 has a reputation beyond reputecdebodt44 has a reputation beyond reputecdebodt44 has a reputation beyond reputecdebodt44 has a reputation beyond reputecdebodt44 has a reputation beyond reputecdebodt44 has a reputation beyond reputecdebodt44 has a reputation beyond reputecdebodt44 has a reputation beyond reputecdebodt44 has a reputation beyond repute
Default Draining AV gas
Just wondering peoples experience with AV gas, leaving it in the sled for the summer. Do you normally drain and replace with fresh before the season? Current sled is a 17 Axys with a Silber kit.
I know AV has a longer shelf life than 91, but don’t have experience with this yet.
Thanks.
Rate this post: Yes | No
  #2
Old 11-28-2018, 06:56 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Currently: Never enough snow!!!
BILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond repute
Default
Leave it, its fine. Top up with fresh and good to go. Its has a much longer shelf life than 91 (years).
Sent from my SM-G925W8 using Tapatalk
__________________
Derek B.
2000 440 xc sp 136 (EDGE)
2003 800 RMK 162
2004 910 PRO-XR 121x1.75", Wheelie Machine!!!
2011 LRod 13.6 800 ProRMK 3"PC KMOD/Raptors kmod 37" arms Ti can
The Following User Says Thank You to BILTIT For This Useful Post:
cdebodt44 (11-28-2018)
  #3
Old 11-28-2018, 08:03 PM
Dazzler's Avatar
Dazzler Dazzler is online now
Currently: Hobbling on crutches
Dazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond repute
Default
Thanks.
I have run av gas in my sleds, turbo and n/a since 2003, I just top off with fresh and go, never had an issue.
The Following User Says Thank You to Dazzler For This Useful Post:
  #4
Old 11-28-2018, 09:27 PM
revrider07 revrider07 is online now
Currently: 850 modder
revrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond repute
Default
I never drain it just top it off AV gas has to meet a standard to keep octane rating of a year per aviation guide lines. At least it used to be when I was flying.
  #5
Old 11-28-2018, 11:25 PM
BeartoothBaron BeartoothBaron is online now
Currently: Not set.
BeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond repute
Default
My routine is to top off the tank with Stabil and ethanol-free in the spring, then run a half can of Sea-Foam in the first fill of the season. Never had an issue, and I'm sure Avgas is even less likely to degrade. Actually, on that topic, I have a car that hit a deer a couple years ago and I haven't been able to scrape together the time, money, and room to fix (one of the downsides of building your own house, I'm lucky I rode at all last season) – anyway, I fire it up every six months or so, and so far it starts up like I'd run it yesterday.
If you've got time and money to burn and want to do the absolute safest thing, then drain and refill with fresh. Practically speaking though, unless the fuel you left in it was suspect, I say just run it.
  #6
Old 11-29-2018, 12:12 AM
Ride_The_Rockies Ride_The_Rockies is online now
Currently: Waiting for the snowstorm of the Century
Ride_The_Rockies has a reputation beyond reputeRide_The_Rockies has a reputation beyond reputeRide_The_Rockies has a reputation beyond reputeRide_The_Rockies has a reputation beyond reputeRide_The_Rockies has a reputation beyond reputeRide_The_Rockies has a reputation beyond reputeRide_The_Rockies has a reputation beyond reputeRide_The_Rockies has a reputation beyond reputeRide_The_Rockies has a reputation beyond reputeRide_The_Rockies has a reputation beyond reputeRide_The_Rockies has a reputation beyond repute
Default
I guess I am the minority here. I always drain mine and put fresh gas in. I don’t think the AV gas will go bad over the summer, however, there will be a little water from condensation. It takes me 20 minutes to pump it out and dump it in my Jeep and fill my sled up with fresh gas. Besides it's something to do while your waiting for it to snow
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #7
Old 11-29-2018, 05:55 AM
xpspenziv's Avatar
xpspenziv xpspenziv is online now
Currently: boooasting
xpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond repute
Default
I run straight av in my junk. 17 Axys. I drain it and put in my lawnmower,weed eater and chainsaw oil for the winter. No need to waste money on stabil. Fill it with fresh. #7@3-6000 and never an issue. My siber runs flawless with straight AV an a splash of oil @ 7#. That is were people screw up. 865 miles when first belt let go. You wanted a hot rod sled. Feed it good.
The Following User Says Thank You to xpspenziv For This Useful Post:
revrider07 (11-29-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Draining gas tank Thread Starter — Daveferrier1 Forum — Polaris Replies — 3 Last Post — 05-07-2018 12:27 AM
Thread — draining antifreeze Thread Starter — bluedxj Forum — Polaris: EDGE Replies — 2 Last Post — 10-16-2014 03:38 PM
Thread — Draining coolant-M8 Thread Starter — hurricane2 Forum — Arctic Cat: M Series Replies — 1 Last Post — 04-22-2011 03:48 PM
Thread — Draining Chaincase Thread Starter — paramuir Forum — Polaris: 900 Replies — 14 Last Post — 12-16-2009 09:48 AM
Thread — Draining Fuel? Thread Starter — rookie23 Forum — Ski-Doo Replies — 3 Last Post — 12-14-2008 06:32 PM
no new posts
