Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 11-19-2018, 10:30 PM
Rmalo Rmalo is offline
Currently: Not set.
Basic Member
Rmalo is an unknown quantity at this point
Default 2015 Pro RMK Piston/Cylinder Scoring
These pictures are from a 2015 Pro RMK with only 400 miles on it. I am wondering if anyone has an idea as to what would cause this type of wear so quickly? Poor compression 90psi MAG / 70 psi PTO is what led us to pull the jugs and inspect pistons/cylinders.
I noticed right away that the pistons/cylinders looked dry and were not getting enough lubrication. I am going to check crank run out and inspect case for any damage. If the lower half is ok will a hone/replate fix the damage to the cylinder?
Thanks in advance to any reply's. This is my first post on SnoWest and I appreciate all the information you guys post on here.
Rate this post: Yes | No
  #2
Old 11-20-2018, 09:39 AM
Octanee Octanee is online now
Currently: Not set.
Octanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond repute
Default
I'd guess lack of lubrication, looks like some aluminum stuck to cylinder wall who his a good sign of that. Supposedly the sleds. Are way lean from the factory, I turned my pumps up so I seem to be around 35:1 or richer.
  #3
Old 11-20-2018, 02:10 PM
Vincenthdfan Vincenthdfan is offline
Currently: Lifetime Member
Vincenthdfan has a reputation beyond reputeVincenthdfan has a reputation beyond reputeVincenthdfan has a reputation beyond reputeVincenthdfan has a reputation beyond reputeVincenthdfan has a reputation beyond reputeVincenthdfan has a reputation beyond reputeVincenthdfan has a reputation beyond reputeVincenthdfan has a reputation beyond reputeVincenthdfan has a reputation beyond reputeVincenthdfan has a reputation beyond reputeVincenthdfan has a reputation beyond repute
Default
Read up too on oil caps not venting properly.
They can create a vacuum and starve motor of oil too...lots and lots of reading in your future. (Been there, done that)
  #4
Old 11-26-2018, 08:16 AM
RMK900Tractor RMK900Tractor is online now
Currently: Not set.
RMK900Tractor has a reputation beyond reputeRMK900Tractor has a reputation beyond reputeRMK900Tractor has a reputation beyond reputeRMK900Tractor has a reputation beyond reputeRMK900Tractor has a reputation beyond reputeRMK900Tractor has a reputation beyond reputeRMK900Tractor has a reputation beyond reputeRMK900Tractor has a reputation beyond reputeRMK900Tractor has a reputation beyond reputeRMK900Tractor has a reputation beyond reputeRMK900Tractor has a reputation beyond repute
Default
More info....
https://www.snowest.com/forum/showthread.php?t=440993
__________________
2014 Polaris Pro
  #5
Old 11-26-2018, 10:11 AM
SRXSRULE SRXSRULE is online now
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
Default
It could also be cold seize related. You need to let these engines warm up to 100-110* everytime before you even try and move the sled.
  #6
Old 11-28-2018, 09:57 AM
gtwitch gtwitch is offline
Currently: Not set.
gtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond repute
Default
Ditto on the warm up and possible cold seize, I like at least 45 to 55 to one ratio on fuel to oil. I had 55:1 on my 11 pro after some issues and it is happy with its new owner now!!
gtwitch in wyoming
  #7
Old 11-30-2018, 09:45 AM
NapaMatt's Avatar
NapaMatt NapaMatt is offline
Currently: Stocking shelves, Need Parts??
NapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond repute
Garage
Default
X3 ON Warm up!!!
Yes the do run, or move if you hit the ran after they are running... Doesn't mean.. she is ready to rip.. got to warm her up.. slowly ... then she will scream later!!!
wait till u see the temp come up to 100 before moving!!
__________________
FOR SALE... SLP Pipe Set For Pro RMK 800... PM. Me for Details BRAND NEW 2013 ASSAULT PIGGY BACK FRONT SHOCKS FOR SALE!! $$650!!! Gas Tank From a 07 Switchback/ Seat Red and Black No tears. Plus fuel lines.
http://www.napaonline.com/
Theye Supply 1-507-533-6610
Auto Parts, Snowmobile, ATV, Truck and Trailer.. and
Shop Local!!
  #8
Old 11-30-2018, 12:20 PM
peaceofwork peaceofwork is offline
Currently: Internet Rmkpro 800apprentiship
Basic Member
peaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond repute
Default
Warm it up? I thought these sleds were designed to run in the cold wth? Seriously though warm it up even after a hard run and shut down once refiring it give it a moment tor temps to equalize before hitting on the hammer again.
  #9
Old 12-04-2018, 01:09 PM
rydningen's Avatar
rydningen rydningen is offline
Currently: Not set.
rydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond repute
Default
What pistons, stock or aftermarket forged? Seen a few seized forged pistons, definitely not as forgiving as the stock cast ones.
But, oil starvation might very well be what caused this. Vent oil cap, change fuel filter, replate cylinder, get some stock pistons to put in it.
Should be good to go
__________________
Axys PRO 800 155
  #10
Old 01-16-2019, 08:55 PM
extremesanity extremesanity is offline
Currently: Not set.
Basic Member
extremesanity is an unknown quantity at this point
  #11
Old 01-17-2019, 07:45 AM
Currently: Not set.
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Slight cylinder/piston scoring - Hone or replate? Thread Starter — TheBreeze Forum — Arctic Cat: TURBO Replies — 19 Last Post — 02-12-2012 09:11 AM
Thread — Piston scoring! How much is to much? Thread Starter — SnowBound Forum — Performance/Modified Replies — 7 Last Post — 05-06-2009 08:02 AM
Thread — Piston scoring 07 d7 Thread Starter — srosscojw Forum — Polaris Replies — 0 Last Post — 12-19-2008 11:53 AM
Thread — 900 RMK Piston Scoring Thread Starter — donbrown Forum — Polaris Replies — 8 Last Post — 11-10-2008 10:37 PM
Thread — 900 RMK Piston Scoring Thread Starter — donbrown Forum — Polaris Replies — 0 Last Post — 11-10-2008 10:52 AM
no new posts
