Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 02-15-2016, 01:21 AM
pat.m23 pat.m23 is offline
Currently: Not set.
pat.m23 has a brilliant futurepat.m23 has a brilliant futurepat.m23 has a brilliant futurepat.m23 has a brilliant futurepat.m23 has a brilliant futurepat.m23 has a brilliant futurepat.m23 has a brilliant futurepat.m23 has a brilliant futurepat.m23 has a brilliant futurepat.m23 has a brilliant futurepat.m23 has a brilliant future
Default 2015 rmk turbo tunning help
Hi ihave a 2015 rmk pro turbo its the boondocker air to air intercooler kit i also have a rk tek rev 2 topend with the 10.5 turbo head. I am running the 3* boondocker timing key as well and i am at sea level riding up to 4000ft. I was running av gas but i am going to switch it up to vp110. I want to run 10 to 12 lbs of boost and i need a starting point for my numbers. I tried the numbers boondocker recommend on av gas at 10lbs and it leaned out 3 mins into the ride and i drove 8 hours to ride and couldnt ride. I was canada on the coast and the air was dry i hope one of u can help me with a starting poing with my numbers on my box going back up in march and dont want to make that mistake again thank you pat
Rate this post: Yes | No
  #2
Old 02-18-2016, 11:13 PM
Currently: Not set.
Default
No one?
  #3
Old 02-19-2016, 12:40 AM
RobertTrivanovic's Avatar
RobertTrivanovic RobertTrivanovic is offline
Currently: Having an awesome start to winter!
RobertTrivanovic has a reputation beyond reputeRobertTrivanovic has a reputation beyond reputeRobertTrivanovic has a reputation beyond reputeRobertTrivanovic has a reputation beyond reputeRobertTrivanovic has a reputation beyond reputeRobertTrivanovic has a reputation beyond reputeRobertTrivanovic has a reputation beyond reputeRobertTrivanovic has a reputation beyond reputeRobertTrivanovic has a reputation beyond reputeRobertTrivanovic has a reputation beyond reputeRobertTrivanovic has a reputation beyond repute
Garage
Default
Just start throwing fuel in the lean areas.... You should learn to tune your sled fully yourself so you dont run into these issues. Im not saying a good base map doesnt help but since no one is giving you anything im sure you could figure it out on your own... Thats the beauty of all the new turbo kits, for the most part they are getting pretty easy to tune!
__________________
Boosted pro rmk
  #4
Old 02-21-2016, 12:14 AM
Currently: Not set.
Default
Im not saying i cant tune it i was just looking for a place to start sence the place i had to start was not to good lol
  #5
Old 02-21-2016, 12:40 AM
Spaarky Spaarky is online now
Currently: Moved Into Maximum Security Cell
Spaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond repute
Default
Quote:
You know how many different settings there is in a 3D boondocker controller. It's not for the novice operator/tuner. Need someone to teach you.
  #6
Old 02-21-2016, 11:01 AM
briand briand is offline
Currently: Not set.
briand has a reputation beyond reputebriand has a reputation beyond reputebriand has a reputation beyond reputebriand has a reputation beyond reputebriand has a reputation beyond reputebriand has a reputation beyond reputebriand has a reputation beyond reputebriand has a reputation beyond reputebriand has a reputation beyond reputebriand has a reputation beyond reputebriand has a reputation beyond repute
Default
Quote:
I have a 12 pro with a boondocker turbo and dropin kit rev 1 with the 12.1 turbo domes. What i have found is this motor loves to be running at 8400 - 8500 rpm. I also run at 10 pounds of boost at my elev.of 2000 ft with a mix of 34% premium and 66% 110 race fuel. no det problems. Also to get the rpms that this combo likes i had to ditch the 3* timing key and run on the premium setting. I started out with the numbers boondocker sent out and in the 4500 rpm non boost range i added 2 at 0% 2 at 33% 1 at 66% and 1 at 99% range. 5500 rpm non boost range i added the same amount. All other numbers I left alone.
in cruising range on the a/f gauge i will see a/f numbers in the 15 range but have not had any issues. hopefully this helps you out a little. i have also attached my starting no.s
File Type: pdf PolarisProRMK_11-15_StartingNumbers.pdf (138.3 KB, 63 views)
  #7
Old 02-26-2016, 11:37 PM
Currently: Not set.
Default
I was thinking of doing the same thing and adding alittle fuel in the mid range too and mayb i will try doing a mix i will b running 10 to 12 lbs of boost with the 10.5 head i will prob start with a 25 75 mix of pump n 110
  #8
Old 01-13-2019, 01:38 PM
sledhead_79's Avatar
sledhead_79 sledhead_79 is online now
Currently: RIP Stormy
sledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond reputesledhead_79 has a reputation beyond repute
Garage
Default
What range of numbers is one supposed to be searching for? You mentioned 15 range with no issues. If I understand right, lower is richer, higher is leaner. What are guys shooting for A/F ratio?
  #9
Old 01-13-2019, 02:14 PM
Dazzler's Avatar
Dazzler Dazzler is offline
Currently: Hobbling on crutches
Dazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond repute
Default
Are you on or did you try the ethanol setting? That will dump in more fuel. I ran all my Polaris turboed sleds on that setting with boondockers numbers with no issues, I had to pulled a little fuel out of the bottom end on my 2013 @ 6lbs but my 2015 was stock engine @ 12lbs, boon dockers #'s and never missed a beat. I ride 4000' - 7000' mostly.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2015 Pro Rmk 163 MtnTk Turbo Thread Starter — snowhunter87 Forum — Polaris (Swapmeet) Replies — 12 Last Post — 02-11-2016 01:54 PM
Thread — power commander and turbo tunning? Thread Starter — skibum_1260 Forum — Arctic Cat: TURBO Replies — 3 Last Post — 03-02-2011 10:08 PM
Thread — tunning turbo sled on stand Thread Starter — 1badcowboy Forum — Polaris: TURBO Replies — 9 Last Post — 02-21-2010 09:51 AM
Thread — Turbo tunning?? Thread Starter — TheYamMan Forum — Performance/Modified Replies — 0 Last Post — 01-11-2009 08:53 PM
Thread — BD Turbo Nytro Tunning Tips Wanted??? Thread Starter — West Coast Sleds Forum — Performance/Modified Replies — 8 Last Post — 04-28-2008 11:14 PM
no new posts
