#1
About 650 miles. Rode yesterday and sled was running great. On way back about mile from truck check engine light and limp mode. Shot still worked. Loaded up and took to dealer. P0264 (Etec PTO injector open circuit or shorted to ground) and P0270 (Throttle body MAG injector open circuit or shorted to ground). Dealer had no time to get on it so brought home and took off hood and looked for loose/damaged wiring. Everything seemed to be good. PTO injector connector had no dielectric grease. Read where guys had codes with airbox sensor wiring damaged. Put back together and made sure airbox sensor was tight and no more codes. If I unplug that sensor CEL returns. Plug in and ride around and working great. This am go for ride and 5 miles in CEL light but also says "check engine " on dash. Limp mode. SHOT tries to work but wont.
Anyone had issues like this before? I know about 17 wiring but it all looked good. Maybe ECU? BTW... How can I see codes on display? Last edited by salmonbum; 01-18-2019 at 06:46 PM. |
#2
The wires would still be my first guess. Though with as much electronics on these it could be anything.
__________________
2019 Summit X 850 175X3" |
#3
I'd be looking at the stator, when there going south, gremlin's start popping up when they get hot...
__________________
18 G4 165X 3" 15 XM 163 X Turbo 13XM163 X killed by a moose 05 RTK1 154 mod dead and gone (thanks god) 06 800HO 154 mod |
#4
That's what I was thinking, that or ECU. Whats Odd is both codes popped up at same time.
#5
The reports on the injector wiring issue said you could not visually identify the break. It was under the ziptie and insulation was intact. It was the booster injectors IIRC. Maybe jiggle those while it's running, and any other wires with tight looking zipties.
The Following User Says Thank You to Wapow For This Useful Post: | ||
sledhead_24_7 (01-19-2019) |
#6
Dang it I should have left the old Turbo Etec there for you for a back up! What stinks is I bet the snow was really good.
#7
![]() Quote:
I grabbed a flight home. At airport now. At least I get to go home and see ol Wyatt dog for a day until I leave again. |
#8
Update....... 2 wires were busted in main harness. Dealer patched up so I could ride. Seems to run better than ever.
The Following 4 Users Say Thank You to salmonbum For This Useful Post: | ||
#9
Tell us where he found the faulty wiring? Same place as the 2017 models?
#10
I was told it was in the main harness. If you follow DI injector wiring back they goto a plug. Follow past that to other side and into the main harness.
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Thread — limp mode | Thread Starter — mmsports | Forum — Arctic Cat: Proclimb M | Replies — 10 | Last Post — 02-25-2014 11:23 AM |
Thread — 08 m8 engine problems. limp mode? | Thread Starter — bartonls | Forum — Arctic Cat: M Series | Replies — 9 | Last Post — 02-16-2012 12:44 PM |
Thread — Is there a failsafe mode(limp mode) on Nytro if overheat going down the trail? | Thread Starter — snowmanx | Forum — Yamaha: 4-Stroke | Replies — 9 | Last Post — 01-04-2012 08:20 PM |
Thread — 07 D7 limp mode | Thread Starter — xcfreerider | Forum — Polaris: IQ | Replies — 1 | Last Post — 01-01-2012 10:37 AM |
Thread — F8 -07 limp mode? | Thread Starter — fleshball | Forum — Arctic Cat: M Series | Replies — 0 | Last Post — 02-03-2011 01:12 PM |
