Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 12-06-2018, 11:04 AM
PApoo PApoo is offline
Currently: Not set.
Basic Member
PApoo is an unknown quantity at this point
Exclamation mid range bog, dies when warm, first pull restart
Good Morning,
I am having some issues with a 2012 assault 800 and need some help. The sled starts and runs fine for 6-10 minutes with a slight mid range bog. Pulls 8,150rpm with no problem but occasionally has a "dead miss" and comes right out of it in the first 6-10 Minutes. Fast forward after the initial 6-10 minutes and it goes into a bog fit in the midrange, and WOT. Sometimes at WOT it will pull 8,150rpm and shut right off like someone turned the key off... lights and gauge stay lit until sled comes to ALMOST a dead stop. Pull the rope and the thing come right back alive but when you go to move it again its in a fit of rage.. misfiring, kinda of acting like it runs out of fuel. Heres what ive done so far..
Stator: was claimed to be replaced by the previous owner.
ECU: i just replaced with Brand new, and had it programmed by dealer. ( No fix )
EV solenoid and piping: taken off a known running sled with same P/N's ( no fix)
EV's: Cleaned by myself. all passage ports, bellows cleaned and inspected etc. ( i dont trust many shops, Also no fix )
Voltage regulators: ( there are two ) taken off a known running sled , Also no fix )
Capacitor: swapped from a known running sled ( no fix )
Primary spring: not broken
Compression: 128/128PSI
Charging at approx 12.7V
Had EV solenoid code, cleared it and ran it again into its fit, never came back.
fuel pressure: constant approx 56-57psi ( harbor freight gauge...) idle, mid fit, and WOT it doesnt deviate.
checked all wires i could see.
Plum full tank of fuel...
I am at a total loss with this thing...
Ive searched high and low and cannot find anyone with a problem exactly like this. happens everytime when ran from cold to warmed up, 10 minutes and it acts up. let it cool and it will do it all over again.
Sometimes it doesnt start and you have to hold the trottle open to restart, and sometimes reverse button once its hit will turn the sled off.
Please someone help. im ready to watch it burn.
Ps: Dealer just replaced battery and speed sensor, havent gotten the chance to run it yet.
Rate this post: Yes | No
  #2
Old 12-06-2018, 12:42 PM
Solarguy's Avatar
Solarguy Solarguy is online now
Currently: trials213mt@gmail.com
Solarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond reputeSolarguy has a reputation beyond repute
Default
I'd try a throttle cable adjustment, had a couple sleds do funny things that were cured by a cable adjustment. Make sure the lever has some play, mine had tightened through vibration and simply loosening a bit solved the problems.
  #3
Old 12-06-2018, 02:10 PM
NapaMatt's Avatar
NapaMatt NapaMatt is offline
Currently: Stocking shelves, Need Parts??
NapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond reputeNapaMatt has a reputation beyond repute
Garage
Default
exh. sensor!!
do a ohm test!!!
__________________
FOR SALE... SLP Pipe Set For Pro RMK 800... PM. Me for Details BRAND NEW 2013 ASSAULT PIGGY BACK FRONT SHOCKS FOR SALE!! $$650!!! Gas Tank From a 07 Switchback/ Seat Red and Black No tears. Plus fuel lines.
http://www.napaonline.com/
Theye Supply 1-507-533-6610
Auto Parts, Snowmobile, ATV, Truck and Trailer.. and
Shop Local!!
  #4
Old 12-27-2018, 09:30 AM
Hansen13 Hansen13 is offline
Currently: .
Hansen13 has a reputation beyond reputeHansen13 has a reputation beyond reputeHansen13 has a reputation beyond reputeHansen13 has a reputation beyond reputeHansen13 has a reputation beyond reputeHansen13 has a reputation beyond reputeHansen13 has a reputation beyond reputeHansen13 has a reputation beyond reputeHansen13 has a reputation beyond reputeHansen13 has a reputation beyond reputeHansen13 has a reputation beyond repute
Default
My similar (Not Exact!) issue turned out to be coils. It'd be great until they hit a certain temp then one would fail basically killing the sled. Chuck snow on them and you could ride it all day. They'd get heat soaked. Replaced coils and issue was gone.
  #5
Old 12-27-2018, 01:36 PM
NapaMatt's Avatar
Garage
Default
Also
Could be a bad injector... 2012 had lots and lots of bads ones
__________________
Shop Local!!
  #6
Old 12-27-2018, 10:50 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
And if all that doesn't work, I'd have the dealer go through to calibrate AND set the TPS.
They must be calibrated before they are set.
__________________
OEM parts from Free Agent
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Ambassador for:
FB & IG: Scott Stiegler
Check out these cool products:
Reply
Bookmarks
Tags
800, assault, bog, polaris, pro ride
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — mid range bog Thread Starter — polarisgomer Forum — Polaris: Pro-Ride Replies — 6 Last Post — 01-10-2018 05:49 PM
Thread — 05 fusion 900 starts right up dies once warm then won't restart Thread Starter — C.parry95 Forum — Polaris: 900 Replies — 1 Last Post — 09-14-2015 09:53 AM
Thread — Mid range bog on 05 M7? Thread Starter — powerstroke 350,700 Forum — Arctic Cat: M Series Replies — 1 Last Post — 02-01-2015 02:19 PM
Thread — mid range bog Thread Starter — Blu Du Forum — Ski-Doo: XM Sleds Replies — 0 Last Post — 12-30-2012 08:43 PM
Thread — mid range bog? Thread Starter — DragonFreak Forum — Polaris: TURBO Replies — 0 Last Post — 01-23-2010 07:23 PM
no new posts
