ACT Drive
C
Crash Cat
New member
Feb 16, 2008
42
51
I have a couple questions that the dealer seemed a little shaky on.
What is the amount of fluid for a 2008 M8 SP and a 2011 M8 SP?
Also which oil to use for each?
How much flush should i use and what is the best way to use it?
The dealler sold me Act acer reverse gearcase fluid (15 oz PN #5639-219) for the 2011, and ACT reverese gearcase fluid (12 oz PN #4639-628) for the 2008. He said that i should drain, then fill with the 6 oz bottle of flush. Start sled spin track a little the drain flush and refill with gearcase fluid.
Does this sound correct? Thanks for the help.
Keith
silverram323
224
96
Cambridge, MN
www.beyondsynthetics.net
Fluid amounts sound right, If i were you i would take a extra hour to take the DD out and open it up to make sure you have no problems in there. some sleds had some DD bearing issues and if nothing done it will take out the DD system and cost you a small fortune.
here is the thread on the bearing failure, long read but worth your time.
http://www.snowestonline.com/forum/showthread.php?t=151644
Also you can use AMSOIL gear Oil click here
