Ok last year I ran the thermostat with the bypass with a reducer in it to limit the pressure spike when the thermostat was closed. I heard some guys where running the thermostat with the bypass plugged so I installed the thermostat in my sx with the bypass plugged and I put a pressure gage on it today and found with the thermostat closed, I could build 45-50 lbs. granted this pressure is just between the water pump and the thermostat, which is mostly in the block, but seems high to me. Are you guys drilling a bigger hole in the thermostat itself to lower he pressure or are you just not worrying about it??? Allan?? Anyone.???
