R
Has any one ran a Powderlites stage 3 turbo with a Begi Fuel Pressure Regulator. I have a 2025 Rising rate fuel regulator and am running the from the fuel pump to the rail, then out the other end to the Regulator. Im looking for the settings for the regulator, the Fuel pressure at idle and set up, and the small screw on the side. And where are you feeding the boost inlet from the throttle body vacuum line or from the front of the intercooler.
