I made the swap and wouldn't go back. My Keihins would make the sled bog every once and a while. (Keihins) When the needle and seat go bad, and a new needle doesn't fix it. You have to buy a new carb. The Keihins also had to be cleaned thoroughly especially the pilot jet. You can spray carb cleaner through it and it won't come clean. You have to use a torch tip cleaner ( or a small object) to run through it (not boring) to get the jet clean, or else you will have a lean pop at idle. Don't get me wrong they are still a good carb. The Mikunis flat sides have replaceable needle and seats, and are very responsive. Like everyone else has said everyone has parts.
