Does anybody know if the 600 sport (carb) machines (2011 &2010) have a DPM like the 800 ptek?
If its carburated it has dpm, unless its a flatlander, it was an option. If its fuel injected there is no need for dpm as all fuel injection is computerized and altitude compensation is built in!
I looked for this option on the skidoo web site and could not find it. The reason i am so curious is cause i am interested in purchasing one from mnt pull if they have dpm.Are the 600 summit sports the 500 ss motor or the 600 ho?
IMO there is a big differance.
The summit sport is the 500ss engine - not the 600HO. I don't know how to tell you guys, but that sled doesn't have DPM. I have one of them in the garage. Totally disassembled it... put new plastic on it, put 600RS based 700HO in it.
The stock engine is a 500ss and they have no dpm. Wish it did. Guess who my 2011 Summit sport came from! Mt. Pull's dealer must have jetted the sled for his elevation. I want to say it had a 320 or 330 main jet in it... when it came from Utah. Stock they are jetted with a flat lander 420 and the dealer has to jet them for the altitude that you are going to be riding them at. Tomorrow I will go out and read the main jet that came out of the sled (500 ss) to confirm.
You can chose to believe me or not..... the Summit Sport is the low cost version to get into sledding in the mountains and has no dpm, has the 500ss engine... and is very durable. The 500ss runs pretty good in that sled because of the light weight. The 800R Pteks had dpm.
In 2010 and 2011 the 600HO engine in the summit was the ETEC.... didn't need dpm.
Adam, you wouldn't believe that sled now. I think the only original parts are the tunnel, e and s members, rear bumper and track, the rest has been replaced... ok, has stock wiring harness and cluster. ECU has been recurved by tom lawrance to hot 700 curve. ha ha.. now I am wishing I had put the 800R wiring harness on and with that recurved ECU, then I could put DPM on it. Ha ha.. would make more sense to have DPM on the mountain sled then the 700HO flat land sled.
Cory3671; there was no carbed 600HO in 2009. There was no Summit Sport in 2009. There was a Summit Everest 500ss which was the only 600 carbed summit sled in 2009. The only 600HO was the Etec in 2009. Go look at the doo fiche.. it spells it out.
