I followed the directions to load , but not sure if it took??
2 2mileshigh Active member Nov 26, 2007 380 44 28 Dec 20, 2012 #1 I followed the directions to load , but not sure if it took??
P poolaris Free Member Jan 1, 2012 38 6 8 Dec 20, 2012 #2 when you open your pcv and hit get map or whatever it is! it loaded up then you hit send map when you do this, look in the bottom left corner it tells you that the pcv is retrieving the map and when you send it it says sending map...map sent
tinkerjohnson Well-known member Premium Member Dec 12, 2008 1,168 262 83 Southern utah Dec 21, 2012 #3 map i had this same question, all you need to do is turn on the show notes setting. go to view and click on show notes and then when you plug into your pvc it will say what map you have,
