Everyone-Quit making it so difficult - the easy way it to put a floor jack under the handle bars- 1st- raise the jack as high as it will go- tip the sled on the side guiding the brake side to rest in the jack cup- then all you have to do is lower the jack till the sled is horizional-
I find it easier to tip the sled with the jack all the way up- undo all the bolts except for the bottom two- lay it over and remove the bottom two-
You won't loose a drop of oil- don't have to worroy about no vent tube or nuttin--- easy cheesy:high5:
S/C
