Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 06-09-2019, 06:25 PM
Badv2 Badv2 is offline
Currently: Not set.
Basic Member
Badv2 is an unknown quantity at this point
Default 2000 mile maintenance
I have a 17 mountain cat with 1700 miles was considering doing all drive bearings and possibly top end and clutch rebuild. Was just wondering when others were doing these things don't want to throw a bunch of parts at it but don't want mid season problems.
Rate this post: Yes | No
  #2
Old 06-09-2019, 08:34 PM
kanedog kanedog is online now
Currently: Undefeated Mountain Clutching Champ of the World!
kanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond repute
Garage
Default
If two years or older I like to do the drive bearings. Great idea. If mountain riding, new or rebuild clutches at 1000 miles. It's heli removal only where I sled so Im more anal. Cheers
Sent from my SM-G920W8 using Tapatalk
The Following User Says Thank You to kanedog For This Useful Post:
Badv2 (06-09-2019)
  #3
Old 06-09-2019, 08:57 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
wow I have same sled about same miles, regular clutch cleans, needs nothing that I can see.
  #4
Old 06-10-2019, 08:28 AM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
Drive bearings in most cases will go well into the 4k mile range. If you would like to pull the outer seal off and re grease this is a good step on the clutch side. the other side is in gear oil and you can inspect them by pulling off the cover. top end 3500 miles primary clutch blow it out with compressed air and take off the cover and replace the primary spring and check the rollers. if sloppy replace clutch with a new one. IMO rebuilding cat clutches is not worth it.
The Following User Says Thank You to kiliki For This Useful Post:
Badv2 (06-10-2019)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 1600 mile maintenance? Thread Starter — RanOutofTalent Forum — Polaris: AXYS Replies — 10 Last Post — 09-02-2018 07:04 PM
Thread — 200 mile maintenance. Thread Starter — norsepeak Forum — Ski-Doo: REV Gen 4 Replies — 6 Last Post — 12-27-2016 07:11 PM
Thread — My 4K mile maintenance job Thread Starter — 94fordguy Forum — Polaris: 900 Replies — 25 Last Post — 03-21-2013 10:11 PM
Thread — What needs to be replaced/rebuilt on a 2000+ mile M7 Thread Starter — AlphaMale Forum — Arctic Cat: M Series Replies — 10 Last Post — 09-12-2009 06:42 PM
Thread — Sled Maintenance. What maintenance needs to be performed and how often? Thread Starter — Schwartz Forum — Polaris Replies — 9 Last Post — 03-17-2009 08:42 AM
no new posts
