Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 03-20-2019, 09:38 PM
Mtncat89 Mtncat89 is offline
Currently: Not set.
Basic Member
Mtncat89 is an unknown quantity at this point
Default 2016 limited 162" skid setup
I find there is too many opinions out there and I'm looking to get my skid setup little better from those who have the same sled and are similar weight. sled is pretty much stock, 3" power claw, evil 3s all around, just trying to get it to climb a little better, I've played around a ton with the shock pressures, rebound etc. Havent touched the limiter strap(it was set all the way out from dealer) running the middle hole at the back of the skid, was planning on swapping to 8t drivers too before the season is over. I'm about 230-240lbs with gear. Any input appreciated.
Rate this post: Yes | No
  #2
Old 03-21-2019, 09:36 AM
kiliki kiliki is offline
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
get the 8t in first it affects the whole set up. this will keep it from trenching to china and in turn will change all your shock settings.
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to kiliki For This Useful Post:
d1100t (03-21-2019)
  #3
Old 03-21-2019, 10:22 AM
d1100t's Avatar
d1100t d1100t is offline
Currently: Towing another Polaris 850 behind my Cat
d1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond repute
Default Setup
The TKI mountain cat drop and roll helps this sled a lot also.
It's a lot of work but if you have the ability it'll work even better with the 8 tooth drivers. Makes it the same as a 2017 Mountain Cat.
I did both of these mods to my 2016 LTD and it made the sled way easier to ride.
  #4
Old 03-21-2019, 08:41 PM
Currently: Not set.
Basic Member
Default
I'll for sure be doing the 8t swap, if i had access to someone's old case I'd consider the dropped case, but I also just had the chain and tensioner replaced under warranty, and I paid extra to revert to the steel lower sprocket vs the stock aluminum one, I found my oil just getting destroyed way too much, and the gear had a fair amount of wear. Hardly noticed a difference going from alum to steel, if any at all
  #5
Old 03-21-2019, 10:43 PM
sno*jet sno*jet is offline
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
what elevation?
the 8s should def. help.
you might try the bottom hole for rear skid mounts. its popular for 153s, helps them climb. might push a bit when flat on a 162 but you like climbing...
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to sno*jet For This Useful Post:
d1100t (03-22-2019)
  #6
Old 03-22-2019, 07:47 AM
715sledUP 715sledUP is offline
Currently: Not set.
Basic Member
715sledUP has a reputation beyond repute715sledUP has a reputation beyond repute715sledUP has a reputation beyond repute715sledUP has a reputation beyond repute715sledUP has a reputation beyond repute715sledUP has a reputation beyond repute715sledUP has a reputation beyond repute715sledUP has a reputation beyond repute715sledUP has a reputation beyond repute715sledUP has a reputation beyond repute715sledUP has a reputation beyond repute
Default
Not to derail the topic but are the shocks the same length on the 153 vs the 162? I have a 153 2.6 Sno Pro with the 8 tooth drivers, was considering going to a 162 power claw 3” but was curious what all has to be changed? I’m still learning and was curious if the longer track would help me at all...
  #7
Old 03-22-2019, 08:39 AM
Currently: Not set.
Garage
Default
track is a direct swap not shocks need to be changed.
715sledUP (03-22-2019)
  #8
Old 03-26-2019, 10:53 AM
Currently: Not set.
Basic Member
Default
Quote:
Originally Posted by sno*jet View Post
what elevation?
I got the driver swap done, man was it a pain to put the skid back in.. I ended up going to the bottom hole on the rear skid just for clearance reasons, on the middle hole there seemed to be enough deflection in the track to hit the cooler, even tightened right up.. dropped to bottom hole and no issue. I took it out Sunday but didnt notice much difference because the snow was ****.. but I ended up tearing my ACL somehow.. so in done for the season now.. I'll have to wait until next season to try it out in pow
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2016 M8000 Limited 162" Thread Starter — cpa Forum — Arctic Cat (Swapmeet) Replies — 4 Last Post — 11-14-2017 04:48 PM
Thread — 2016 M8000 BLACK LIMITED 162" 3" POWERCLAW Thread Starter — Speed Shop Inc. Forum — Black Diamond/Speed Shop Inc Replies — 0 Last Post — 12-02-2016 04:02 PM
Thread — 2016 Arctic cat limited edition 162" x3" Thread Starter — bigsexy*11 Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 04-16-2016 01:12 PM
Thread — 2016 limited rear skid setups? Thread Starter — MrClean409 Forum — Arctic Cat: Proclimb M Replies — 13 Last Post — 01-19-2016 10:56 AM
no new posts
