Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 01-24-2019, 08:44 PM
mk818 mk818 is offline
Currently: Not set.
Basic Member
mk818 has a reputation beyond reputemk818 has a reputation beyond reputemk818 has a reputation beyond reputemk818 has a reputation beyond reputemk818 has a reputation beyond reputemk818 has a reputation beyond reputemk818 has a reputation beyond reputemk818 has a reputation beyond reputemk818 has a reputation beyond reputemk818 has a reputation beyond reputemk818 has a reputation beyond repute
Default Buying a used axys turbo?
I have no experience in the turbo game and I am wondering if I am going to be buying problems. I am fairly adept mechanically and understand more HP = more wear but I don't want to be getting towed out of the mountains on a consistent basis. The sled is a 16' with the non intercooler silber with 800 miles. Any advise helps! Thanks
Rate this post: Yes | No
  #2
Old 01-25-2019, 01:54 PM
Mha1406 Mha1406 is offline
Currently: Not set.
Basic Member
Mha1406 is an unknown quantity at this point
Default
I don't have much technical information/advice but I've bought 3 used pro's (16-17's) with non-intercooled silbers ranging from 300-1400 miles & I've always just checked the basics - compression, oil lines, clutches, etc. & I've never had an issue. A lot of people will tell you to stay away from used turbo'd sleds but I've had nothing but good luck. I believe all 3 of mine had the turbo's installed by Silber which gave me a little more peace of mind. I always ask them what they've been running for oil & fuel (91/av/race gas ratio) & stick with that. Good luck!
The Following 2 Users Say Thank You to Mha1406 For This Useful Post:
mk818 (01-25-2019), raleigh111 (03-26-2019)
  #3
Old 01-25-2019, 02:16 PM
Snowman.PRO. Snowman.PRO. is offline
Currently: Snowman.Pro
Snowman.PRO. has a reputation beyond reputeSnowman.PRO. has a reputation beyond reputeSnowman.PRO. has a reputation beyond reputeSnowman.PRO. has a reputation beyond reputeSnowman.PRO. has a reputation beyond reputeSnowman.PRO. has a reputation beyond reputeSnowman.PRO. has a reputation beyond reputeSnowman.PRO. has a reputation beyond reputeSnowman.PRO. has a reputation beyond reputeSnowman.PRO. has a reputation beyond reputeSnowman.PRO. has a reputation beyond repute
Default
I bought my 16 with 688 miles. Silber @7lbs, Zrp clutch cover. and a z bros front end 39", tki belt drive tensioner. Thats the good...
The bad. I have learned a lot from this sled. The a arm ball joints were all shot on the sled which i didn't notice having it sit on the ground. Put it up on the lift and it had a 1/8"-1/4" play in them. So check those!
I also replaced all the bushings where the a arms bolt on.
I also, had to replace the rubber carb/throttle body boot. Whoever installed the silber kit did a crap job. The BOV reference line that is drilled into the boot was torn. I rode it a season and noticed it the second season. I'm not sure when it tore. Good new was the reeds looks perfect at 1030 miles when I had them out during this.
Replaced all bogie wheel bearings, a few of them were wobbly.
I did get the clutches balanced/serviced at indy specialties.
I'm at 12xx miles now and its never left me stranded. I'd probably buy it again. So minus the maybe 500 I put into parts I didn't expect.
Do a compression test before you buy it, check the ball joints on a lift if you can or have another guy tip it on one side.
Stock belt made it to 1000 miles, I replaced with a new and run that stock as a spare. It still looks good.
Belt drive has been good. 0 issues.
One time it didn't start, sat outside over night 35-40 outside, really foggy. It started up and then died. Wouldn't start up. Flooded it self. tried later on and did the hold the throttle to the bars while pulling. (this gives spark but no fuel) It started right up after a few pulls and ran good the whole trip.
Check those things I listed, I run a little oil in the fuel too. Good Luck
__________________
16 Axys 163x2.6, Silber Turbo, Raptor Kinetic shocks, ZRP Clutch cover, Indy Specialty Balanced clutches
The Following User Says Thank You to Snowman.PRO. For This Useful Post:
mk818 (01-25-2019)
  #4
Old 01-25-2019, 11:55 PM
Currently: Not set.
Basic Member
Default
Thanks for the advice! After reading everything I could find there were very few bad experiences. I'm glad yours were trouble free engine wise as well. I bought the sled today and I am going to go rip tomorrow. It had a half tank with 50/50 av/92 and I fillled it with 5 more gallons of 100ll. Does running more octane than perscribed by silber pose any problems? One thing that did throw me off was where the pipe met the exhaust side of the compressor. It didn't seem to have a perfect seal and is kind of loose. You can wiggle the whole turbo setup. I'm excited to learn everything there is to know about sleds and turbos as I have acended from snowbiking
The Following User Says Thank You to mk818 For This Useful Post:
Snowman.PRO. (01-28-2019)
  #5
Old 01-26-2019, 08:23 AM
willjogervais willjogervais is offline
Currently: Not set.
willjogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond reputewilljogervais has a reputation beyond repute
Default
Make sure every exhaust connection has double springs. And then have fun. Turbos are a wild ride
Edit- if they aren't in good shape, replace the exhaust donuts as well
  #6
Old 01-26-2019, 10:34 AM
turboless terry's Avatar
turboless terry turboless terry is offline
Currently: Not set.
turboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond repute
Default
My buddies 16, which is my old sled, runs straight pump with 5 pound spring. Most riding Is at 8000 to 9500. Stays of it down low and never had any problem. Someday could get a bad batch and have problems. No need to over octane. A couple gallons of av gas would give you peace of mind unless you are running more boost and riding lower elevations. I think I had 500ish on it before I put turbo on it. Sold it to him after 3 rides. This is 3rd season on it and no problems. I think it is having some polaris issues such as crappy relays or TPS issues. Minor I think. Been a great sled. I just rode it yesterday in epic snow. It still gets stuck is the only problem with it.
  #7
Old 01-28-2019, 09:37 AM
Default
This is going to get technical: But if you over octane it with AV gas, it will not run as smooth as say something like VP racing 110.
I run 20-30% mix of Av gas 110LL with 91 octane, sometimes ethanol in it too. Not by choice, but many places only have 91 with ETH. After 2 years riding it, I think 15-20% would get me by, Im usually 8500 ft or higher. If I'm lower elevation, I would take that into consideration.
I've never seen the DET light come on. I have been adding less and less to dial back how much AV gas I use.
I'm on the 7lb spring Silber.
__________________
  #8
Old 01-28-2019, 03:27 PM
Currently: Not set.
Basic Member
Default
Yes turbos are a wild ride! It was awesome! Snowmobiling is more addictive than crack.... also more expensive. Sled ran like **** for the first 5 mins and the check engine light flashed on deceleration multiple times. I assume it was a symptom of sitting for a while and/or bad gas. Once she was warm and off the trail I opened her up on a long pull and she ran perfect the rest of the day. Max RPM i saw was 8350.
I pulled the plugs after the ride and the mag side was a grey color and looked to be running hot. Does this look like it is too lean or hot to anyone? Or normal? The PTO side was a perfect cardboard color. I checked for air leaks with carb cleaner around the crank and intake with no difference in idle. Next i am going to check the reed cage for wear/chipping.
File Type: jpg Screenshot_20190127-175421_Gallery_resized.jpg (93.2 KB, 152 views)
braapin (01-28-2019)
  #9
Old 01-28-2019, 05:03 PM
2XM3's Avatar
2XM3 2XM3 is offline
Currently: 2017 Axys 174 Turbo, 2016Axys 163
2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute
Default
You cant tell anything form that plug picture, ride the sled, get it warm, put in 2 brand new correct heat range plugs, make a nice Full throttle pull, cut it off clean do NOT let it idle, pull plugs and look at the bottom of the porcelain insulator, (with a plug light)
__________________
2013 and 2014 National Superboat Champions
The Following 3 Users Say Thank You to 2XM3 For This Useful Post:
mk818 (01-28-2019), Sheetmetalfab (01-28-2019), willjogervais (01-28-2019)
  #10
Old 01-28-2019, 11:08 PM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is offline
Currently: Power Clawing the Axys....
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
The Following User Says Thank You to Sage Crusher For This Useful Post:
mk818 (01-29-2019)
  #11
Old 01-29-2019, 02:09 AM
kmg kmg is offline
Currently: Not set.
kmg is an unknown quantity at this point
Click Here to Register
  #12
Old 01-29-2019, 07:03 AM
2XM3's Avatar
The Following User Says Thank You to 2XM3 For This Useful Post:
sledhead9825 (03-08-2019)
  #13
Old 01-29-2019, 08:36 AM
2XM3 (01-29-2019)
  #14
Old 01-29-2019, 11:41 AM
Currently: Not set.
Basic Member
  #15
Old 01-29-2019, 10:35 PM
  #16
Old 01-30-2019, 12:05 AM
Currently: Not set.
Basic Member
  #17
Old 02-20-2019, 02:36 PM
  #18
Old 03-07-2019, 10:56 AM
MTN Powderhound's Avatar
MTN Powderhound MTN Powderhound is offline
Currently: looking for a 174 850
MTN Powderhound has a reputation beyond reputeMTN Powderhound has a reputation beyond reputeMTN Powderhound has a reputation beyond reputeMTN Powderhound has a reputation beyond reputeMTN Powderhound has a reputation beyond reputeMTN Powderhound has a reputation beyond reputeMTN Powderhound has a reputation beyond reputeMTN Powderhound has a reputation beyond reputeMTN Powderhound has a reputation beyond reputeMTN Powderhound has a reputation beyond reputeMTN Powderhound has a reputation beyond repute
  #19
Old 03-07-2019, 11:19 AM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Boost is addictive
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
The Following 3 Users Say Thank You to Sheetmetalfab For This Useful Post:
diamonddave (05-24-2019), Snowman.PRO. (03-08-2019), Wheel House Motorsports (07-17-2019)
  #20
Old 03-08-2019, 09:40 AM
snowracer21 snowracer21 is offline
Currently: Not set.
snowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond repute
The Following 2 Users Say Thank You to snowracer21 For This Useful Post:
sledhead9825 (03-08-2019), Snowman.PRO. (03-08-2019)
  #21
Old 03-26-2019, 07:25 AM
goforbroke goforbroke is offline
Currently: Not set.
goforbroke has a reputation beyond reputegoforbroke has a reputation beyond reputegoforbroke has a reputation beyond reputegoforbroke has a reputation beyond reputegoforbroke has a reputation beyond reputegoforbroke has a reputation beyond reputegoforbroke has a reputation beyond reputegoforbroke has a reputation beyond reputegoforbroke has a reputation beyond reputegoforbroke has a reputation beyond reputegoforbroke has a reputation beyond repute
  #22
Old 05-10-2019, 04:40 PM
  #23
Old 07-17-2019, 01:17 AM
CatConvert CatConvert is offline
Currently: Not set.
Basic Member
CatConvert is an unknown quantity at this point
  #24
Old 07-17-2019, 02:04 PM
kanedog kanedog is offline
Currently: Undefeated Mountain Clutching Champ of the World!
kanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond repute
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Planning on buying a axys what year 2016, 2017? Thread Starter — cade123 Forum — Polaris: AXYS Replies — 17 Last Post — 02-25-2017 09:51 AM
Thread — buying m7 turbo Thread Starter — Dmill Forum — Arctic Cat: TURBO Replies — 10 Last Post — 02-25-2010 02:55 PM
Thread — Buying a used turbo Thread Starter — powder express Forum — Yamaha Replies — 11 Last Post — 04-04-2009 10:09 AM
Thread — Looking at buying a turbo...which one? Thread Starter — Shred Master Forum — Performance/Modified Replies — 14 Last Post — 04-12-2008 09:32 PM
Thread — Buying used m8 ovs turbo? Thread Starter — weldab Forum — Arctic Cat: TURBO Replies — 0 Last Post — 03-12-2008 07:44 PM
no new posts
