Upgrade to Premium
Reply
  #1
Old 04-24-2015, 01:26 PM
hobbes's Avatar
hobbes hobbes is offline
Currently: Danger Zone
hobbes has a reputation beyond reputehobbes has a reputation beyond reputehobbes has a reputation beyond reputehobbes has a reputation beyond reputehobbes has a reputation beyond reputehobbes has a reputation beyond reputehobbes has a reputation beyond reputehobbes has a reputation beyond reputehobbes has a reputation beyond reputehobbes has a reputation beyond reputehobbes has a reputation beyond repute
Default Post Forward Kits for Tall Gentlemen
Ok so I'm stretching it a little with the gentleman thing, but I am tall. I noticed this year when sidehilling some steeper lines in marginal snow with my 174 that unless I got myself as far forward as I could, the back end had the tendency to wash out some. I realize I'm asking a lot of my sled to hold a super steep sidehill on crusty snow while hauling a 250 lb 6'5" dude around on it's keester, but was wondering if any tall dudes out there have installed the post forward and what their experiences are. I see C3 and Skinz both make one. I just thought this may be a good way to get my weight forward without having to side step the bars all the time. I hate cheating the angle on the xm's and getting that steering "flop". Thanks in advance for the help and opinions.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #2
Old 04-24-2015, 11:37 PM
powdermuncher powdermuncher is offline
Currently: Not set.
Basic Member
powdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond reputepowdermuncher has a reputation beyond repute
Default
Had the same issue on my 154 and rode my girlfriends sled with sly dog powder hound skis on and it handled sidehills much better. Got a set of 8"sly dog" skis for mine as well and it improved sidehills dramatically to the point where I could move the steering post back a bit for a more balanced ride. While not perfect the skis are a huge improvement. The TMotion and Flex edge track turn in easy but the trade of is it does like to slide the A$$ end downhill easier when trying to hold a line. One thing is if you are to far forward on the sled it gets harder to control the sled in a climb and do fast small line adjustments. That is particularly true with the 174. That is where I found the skis to be the best all around improvement to not give up to much on the other end.
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to powdermuncher For This Useful Post:
hobbes (05-04-2015)
  #3
Old 05-04-2015, 10:29 AM
hobbes's Avatar
Default
So nobody has any reviews or comments about the C3 or Skinz post forward kits? Not looking for a riding lesson, just actual feedback from using these kits thanks!
  #4
Old 05-04-2015, 01:44 PM
tkuss tkuss is offline
Currently: Cmon Pow
tkuss has a reputation beyond reputetkuss has a reputation beyond reputetkuss has a reputation beyond reputetkuss has a reputation beyond reputetkuss has a reputation beyond reputetkuss has a reputation beyond reputetkuss has a reputation beyond reputetkuss has a reputation beyond reputetkuss has a reputation beyond reputetkuss has a reputation beyond reputetkuss has a reputation beyond repute
Default
//www.snowest.com/forum/showthread.php?t=344524
you search through old posts at all? Here is one I dug up real quick, im sure there must a couple more out there, and probably alot of threads about it on dootalk as well.
The Following User Says Thank You to tkuss For This Useful Post:
hobbes (05-04-2015)
  #5
Old 05-04-2015, 02:10 PM
hobbes's Avatar
Default
I did read that one, and most of the other threads I've found dance around the subject a little too. I realize it's going to be purely subjective. I did also read somewhere that some folks had some problems with the Skinz quality, so was hoping to get some clarity on the quality of the kits too. Thanks for the help. Maybe I should just be PM'ing Brew and BCIL...
  #6
Old 05-04-2015, 06:27 PM
TJ427 TJ427 is offline
Currently: Not set.
TJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond reputeTJ427 has a reputation beyond repute
Default
We have them on our XM's and T3's. My wife and I are both on the light side of things so they help us immensely in the backcountry. Bret Rasmussen is the on who turned us onto the post forward concept/product last year and it is a great mod if you like riding the backcountry in situations where you spend a lot of time on one ski. The Skinz post doesn't look the best visually but so working well after one full season (22 days on the mountain for me). Suspect the advantage will be similar for someone who is taller, but moving your weight may produce similar advantages. We have to use our weight moving our feet to the right places while bigger riders can keep on foot on each running board and maintain an edge with out wrong foot forward. I find myself in a much better position on the sled with the post forward. Went from the stock riser, to a 3 inch, and then a 2 inch riser the last twenty days of riding ( I am 5'9). With post forward and 2 inch riser my sled is in a comfortable position on an edge vs stock the bars were in my chest.
The Following 2 Users Say Thank You to TJ427 For This Useful Post:
hobbes (05-07-2015), Idaho Slim (05-04-2015)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Alternative Impact 36" viper forward a arm kits Thread Starter — alt Forum — Vipers! Replies — 16 Last Post — 03-04-2015 10:07 AM
Thread — C post forward#2 Thread Starter — 9071000 Forum — Arctic Cat: Proclimb M Replies — 37 Last Post — 03-13-2014 04:54 PM
Thread — Forward Steering post..How to fill the old post hole? Thread Starter — 01ZRTCAT Forum — Arctic Cat: 1M Replies — 10 Last Post — 01-31-2011 03:55 AM
Thread — Is the '07 M1000 steering post more forward than a '08 post? Thread Starter — ACMtnCat Forum — Arctic Cat: M Series Replies — 6 Last Post — 12-22-2009 12:42 AM
Thread — Rx-1/Vector Rider forward kits Thread Starter — wildchild Forum — Handlebars/Risers (Swapmeet) Replies — 0 Last Post — 12-20-2007 05:36 AM
no new posts
