Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 02-22-2011, 10:42 PM
cranktwister cranktwister is offline
Currently: just snowed 10 " last night winter is comin
Basic Member
cranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond repute
Default No fire
Got no fire on both cylinders,tried fresh plugs but no fire.Motor was starting to bog and miss when you stab the throttle but would clear up and run fine,when I say bog I mean like it would run rich,could really smell rich exhaust,during the same ride the gauge display would come off then on,eventually we stopped to take a brake and it would not restart.Imediately checked for fire to the plugs and nothing on both cylinders.I tested the stator earlier this year and it checked ok.I am wondering if the voltage regulator is toasted.Any ideas would be appreciated.
Rate this post: Yes | No
  #2
Old 02-22-2011, 10:45 PM
Z-Man's Avatar
Z-Man Z-Man is offline
Currently: Wishing I lived closer to the mountains.
Z-Man has a reputation beyond reputeZ-Man has a reputation beyond reputeZ-Man has a reputation beyond reputeZ-Man has a reputation beyond reputeZ-Man has a reputation beyond reputeZ-Man has a reputation beyond reputeZ-Man has a reputation beyond reputeZ-Man has a reputation beyond reputeZ-Man has a reputation beyond reputeZ-Man has a reputation beyond reputeZ-Man has a reputation beyond repute
Default
if you tested the stator earlier this year it may be bad now. Could be a short in your kill switch or wires to the key too. check all the wires for shorts first.
__________________
2014 Ski Doo XM154
2005 RMK 900 ,TM1, VanAmburg, Turbo 162
2005 RMK 900 166 #0016 for sale
2005 RMK 900 163
  #3
Old 02-22-2011, 11:21 PM
sloan188 sloan188 is offline
Currently: Not set.
Basic Member
sloan188 has a reputation beyond reputesloan188 has a reputation beyond reputesloan188 has a reputation beyond reputesloan188 has a reputation beyond reputesloan188 has a reputation beyond reputesloan188 has a reputation beyond reputesloan188 has a reputation beyond reputesloan188 has a reputation beyond reputesloan188 has a reputation beyond reputesloan188 has a reputation beyond reputesloan188 has a reputation beyond repute
Default
I just had a similar problem with mine on the weekend and it turned out to be the stator due to separation of the flywheel. I checked the stator a week ago prior to going on a trip and everything tested fine. My problem was with the blue-yellow, blue-green, blue-red wires 15 ohm wires...one of them was open due to an open stator coil. Luckily I found a used stator and flywheel and had her back on the trails within a few hours.
The Following User Says Thank You to sloan188 For This Useful Post:
Z-Man (02-22-2011)
  #4
Old 02-23-2011, 12:23 AM
Basic Member
Default
I disconnected kill switch,grip warmers and key switch,I dont know if you can get fire with key switch disconnected.The reason I wasleaning towards voltage regulator was it was loose for awhile before I checked the stator earlier,thought it might be banging around and broke internally,I would think that I would get some sort of power out of the stator wether it be the dc side or ac side.Does anyone know on a runnig 900 if you pull it over if the headlights or gauges light up a little while hand cranking like my 02 800 rmk does?Thanks for any info
  #5
Old 02-23-2011, 07:59 AM
Currently: Not set.
Basic Member
Default
won't light during hand cranking...
  #6
Old 02-23-2011, 10:08 AM
jskattum606 jskattum606 is offline
Currently: enjoying the Mountains
jskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond reputejskattum606 has a reputation beyond repute
Default
Back to the Bacics
Check first for good spark then compression and see if the plugs are getting wet
  #7
Old 02-23-2011, 10:17 AM
Basic Member
Default
Quote:
I know that sounded kinda funny,when I crank on my 02 800 rmk the head light slightly lights up because you are turning the engine over enough to produce enough voltage to light the headlight,therefore what I was getting at was if 900 did the same thing.Basically trying to see if it is producing any voltage when hand cranked.
  #8
Old 02-23-2011, 10:18 AM
Basic Member
Default
Quote:
Originally Posted by jskattum606 View Post
Back to the Bacics
Well thats my first thing I check as stated above.no fire to both plugs.
  #9
Old 02-23-2011, 10:54 AM
Currently: Not set.
Basic Member
Default
Didn't sound funny at all...I knew exactly what you meant. The reason it won't work on this sled is that there is a relay that needs to be energized to allow power to be applied to things other than the ignition circuit. The relay isn't energized until after the sled starts; therefore, no lights when hand cranking...
If you have no spark on either cylinder then I would test the stator (even if you recently tested as in my case within a week it went from testing perfect to not so perfect and needing replacement).
Because you have no spark on either cylinder I would tend to believe that it's not a coil problem as it seems strange that both coils would fail at the same time (although stranger things could happen).
You can test the capacitor (although I don't think it does much to prevent you from getting spark).
  #10
Old 02-23-2011, 01:50 PM
Basic Member
  #11
Old 02-23-2011, 07:06 PM
Click Here to Register
The Following 2 Users Say Thank You to jskattum606 For This Useful Post:
cranktwister (02-24-2011), guidoxpress (02-24-2011)
  #12
Old 02-27-2011, 05:46 PM
Basic Member
  #13
Old 02-27-2011, 10:27 PM
guidoxpress's Avatar
guidoxpress guidoxpress is offline
Currently: Tearing up Alaskas BOMB POW
guidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond repute
Garage
The Following 2 Users Say Thank You to guidoxpress For This Useful Post:
cranktwister (02-28-2011), sloan188 (02-28-2011)
  #14
Old 02-28-2011, 01:01 PM
Basic Member
  #15
Old 02-28-2011, 01:16 PM
Garage
  #16
Old 02-28-2011, 04:05 PM
Currently: Not set.
Basic Member
  #17
Old 02-28-2011, 05:21 PM
Z-Man's Avatar
  #18
Old 02-28-2011, 05:44 PM
jsledder's Avatar
jsledder jsledder is offline
Currently: ready for snow
jsledder has a reputation beyond reputejsledder has a reputation beyond reputejsledder has a reputation beyond reputejsledder has a reputation beyond reputejsledder has a reputation beyond reputejsledder has a reputation beyond reputejsledder has a reputation beyond reputejsledder has a reputation beyond reputejsledder has a reputation beyond reputejsledder has a reputation beyond reputejsledder has a reputation beyond repute
The Following User Says Thank You to jsledder For This Useful Post:
Z-Man (02-28-2011)
  #19
Old 02-28-2011, 08:35 PM
Z-Man's Avatar
  #20
Old 02-28-2011, 08:40 PM
Garage
The Following User Says Thank You to guidoxpress For This Useful Post:
Z-Man (02-28-2011)
  #21
Old 03-01-2011, 02:23 AM
Basic Member
  #22
Old 03-01-2011, 11:32 PM
Basic Member
The Following User Says Thank You to cranktwister For This Useful Post:
Z-Man (03-01-2011)
  #23
Old 03-02-2011, 09:58 PM
goat goat is offline
Currently: rebuilding inventory
Basic Member
goat has a reputation beyond reputegoat has a reputation beyond reputegoat has a reputation beyond reputegoat has a reputation beyond reputegoat has a reputation beyond reputegoat has a reputation beyond reputegoat has a reputation beyond reputegoat has a reputation beyond reputegoat has a reputation beyond reputegoat has a reputation beyond reputegoat has a reputation beyond repute
  #24
Old 03-03-2011, 06:33 AM
Currently: Not set.
Basic Member
  #25
Old 03-03-2011, 04:07 PM
Z-Man's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — fire Thread Starter — Polar Express Forum — Avalanche and Survival Replies — 9 Last Post — 01-14-2010 02:13 PM
Thread — Cease Fire! Thread Starter — AkMike Forum — Fouled Plug Replies — 6 Last Post — 08-10-2009 07:38 AM
Thread — My first Fire Thread Starter — Wired1 Forum — Fouled Plug Replies — 6 Last Post — 08-27-2008 07:22 AM
Thread — No fire on two cylinders Thread Starter — pietro75 Forum — Yamaha Replies — 5 Last Post — 01-23-2008 06:16 PM
no new posts
