Upgrade to Premium
Reply
  #1
Old 11-10-2008, 09:24 PM
Deeznuts Deeznuts is offline
Currently: Not set.
Basic Member
Deeznuts is an unknown quantity at this point
Default Windshield trimming
How do you guys trim your windshields and make them look good? I want to trim mine down but I'm not exactly a perfectionist so I think that it might not look right if I do it. Also, what do you cut them with? Thanks.
Rate this post: Yes | No
  #2
Old 11-10-2008, 09:38 PM
tundramonkey's Avatar
tundramonkey tundramonkey is offline
Currently: Wrenching
tundramonkey has a reputation beyond reputetundramonkey has a reputation beyond reputetundramonkey has a reputation beyond reputetundramonkey has a reputation beyond reputetundramonkey has a reputation beyond reputetundramonkey has a reputation beyond reputetundramonkey has a reputation beyond reputetundramonkey has a reputation beyond reputetundramonkey has a reputation beyond reputetundramonkey has a reputation beyond reputetundramonkey has a reputation beyond repute
Default
I used a cutting wheel on mine. Use blue painter tape to mask of the front of the shield. Then draw a line on the tape where your going to make the cut. After that I sanded the cut to smooth it out and then transfered the edging over. You can use a compase to transfer the stock profile lower, or create your own design.
__________________
And the monkey pushes the button
  #3
Old 11-10-2008, 09:42 PM
FriscoProx's Avatar
FriscoProx FriscoProx is offline
Currently: Not set.
FriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond reputeFriscoProx has a reputation beyond repute
Default
Dremmel with cut off wheel.
__________________
2019 Patriot AXYS 155" x 2.6" - in a box, on the back of a semi-truck, somewhere- I hope!
"That wind shield sticker is unnecessary and dangerous but I sure do love Fig Newtons" - Ricky Bobby
  #4
Old 11-10-2008, 10:06 PM
SaberKitty's Avatar
SaberKitty SaberKitty is offline
Currently: Waiting for the new 800 engine...
SaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond reputeSaberKitty has a reputation beyond repute
Default
For mine I did the layout with a Sharpie and blue tape.
And then cut with aviation tin snips.
__________________
2013 M800 Sno Pro Limited Black 153 w/o ES
2012 M800 Sno Pro 153 Vader makeover
And a retired pair of sequential serial number 2008 M8 Nightfire Sno Pros
Black - It's the new green
Away from internet riding for
  #5
Old 11-10-2008, 10:08 PM
CATCRAZY CATCRAZY is offline
Currently: Not set.
Basic Member
CATCRAZY is an unknown quantity at this point
Default
I cut mine with a jig saw and a very fine blade
  #6
Old 11-10-2008, 10:09 PM
AKM8 AKM8 is offline
Currently: Not set.
Basic Member
AKM8 has a brilliant futureAKM8 has a brilliant futureAKM8 has a brilliant futureAKM8 has a brilliant futureAKM8 has a brilliant futureAKM8 has a brilliant futureAKM8 has a brilliant futureAKM8 has a brilliant futureAKM8 has a brilliant futureAKM8 has a brilliant futureAKM8 has a brilliant future
Default
I used a pair of tin snips and then superglued the push on chrome or black trim you use on the edge fo a door on a car. Can get it at Napa or Schucks. I imagine a cutoff wheel would be faster but caused to much build up of melted plastic for me.
__________________
2010 ARCTIC CAT M8 WITH SLP POWDER PROS, XXX MOD RODS SHOCK TOWER VENTING, ODI GRIPS, SLP CAN, MUFFPOT, PEAK PERFORMANCE GAUGE RELOCATION, Q.R.S. GAS CANS X2, REAR BAG, HANDLEBAR BAG, GOGGLE BAG, ARCTIC FX GRAPHICS, HCR 4 WHEEL KIT, FLOAT GUARDS, BDX ANTI STAB KIT, HID LIGHTS, AND SOON TO BE GEO MOD.
RIP:
07 M8 SLP Single Pipe, SLP Intake, V-FORCE 3, SLP Powder Pros, 3" Riser, Koso Single EGT, Boss High-Rise Seat, FastLane Side Vents, Van Amburg Bumper, Ported Tunnel, and BMP Fuel Pressure Gauge, PowerClaw 141 2.25
NORTHERN POWER SPORTS
907-452-2752
WWW.NORTHERNPOWERSPORTS.COM
  #7
Old 11-10-2008, 10:18 PM
SnowBound SnowBound is offline
Currently: Busy Making Vents
SnowBound has a reputation beyond reputeSnowBound has a reputation beyond reputeSnowBound has a reputation beyond reputeSnowBound has a reputation beyond reputeSnowBound has a reputation beyond reputeSnowBound has a reputation beyond reputeSnowBound has a reputation beyond reputeSnowBound has a reputation beyond reputeSnowBound has a reputation beyond reputeSnowBound has a reputation beyond reputeSnowBound has a reputation beyond repute
Garage
Default
I used a small pneumatic hack saw from harbor frieght $10. I used tape to mark where I want to cut. Cut it out and then put my trim from my old windshield on it. Good to go.
  #8
Old 11-10-2008, 10:46 PM
miko miko is offline
Currently: Not set.
miko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond reputemiko has a reputation beyond repute
Default
Quote:
I second that!
  #9
Old 11-10-2008, 11:52 PM
RMK SeVeN RMK SeVeN is offline
Currently: Waiting....
RMK SeVeN has a reputation beyond reputeRMK SeVeN has a reputation beyond reputeRMK SeVeN has a reputation beyond reputeRMK SeVeN has a reputation beyond reputeRMK SeVeN has a reputation beyond reputeRMK SeVeN has a reputation beyond reputeRMK SeVeN has a reputation beyond reputeRMK SeVeN has a reputation beyond reputeRMK SeVeN has a reputation beyond reputeRMK SeVeN has a reputation beyond reputeRMK SeVeN has a reputation beyond repute
Default
1) Mark off with a sharpie
2) Use Dremel with cut-off wheel to cut
3) Sand down top
4) I re-used the black trimming, used a touch of RTV get it to hold
  #10
Old 11-11-2008, 04:28 AM
Yamaha24's Avatar
Yamaha24 Yamaha24 is offline
Currently: XF8000 High Country
Yamaha24 will become famous soon enoughYamaha24 will become famous soon enoughYamaha24 will become famous soon enoughYamaha24 will become famous soon enoughYamaha24 will become famous soon enoughYamaha24 will become famous soon enoughYamaha24 will become famous soon enoughYamaha24 will become famous soon enoughYamaha24 will become famous soon enoughYamaha24 will become famous soon enoughYamaha24 will become famous soon enough
  #11
Old 11-11-2008, 07:37 AM
polarisfornow polarisfornow is offline
Currently: living the dream in the west for good.
polarisfornow has a reputation beyond reputepolarisfornow has a reputation beyond reputepolarisfornow has a reputation beyond reputepolarisfornow has a reputation beyond reputepolarisfornow has a reputation beyond reputepolarisfornow has a reputation beyond reputepolarisfornow has a reputation beyond reputepolarisfornow has a reputation beyond reputepolarisfornow has a reputation beyond reputepolarisfornow has a reputation beyond reputepolarisfornow has a reputation beyond repute
Click Here to Register
  #12
Old 11-11-2008, 05:35 PM
d-five d-five is offline
Currently: Not set.
Basic Member
d-five is an unknown quantity at this point
  #13
Old 11-11-2008, 11:14 PM
RockyMtn.Kris RockyMtn.Kris is offline
Currently: Not set.
Basic Member
RockyMtn.Kris has a reputation beyond reputeRockyMtn.Kris has a reputation beyond reputeRockyMtn.Kris has a reputation beyond reputeRockyMtn.Kris has a reputation beyond reputeRockyMtn.Kris has a reputation beyond reputeRockyMtn.Kris has a reputation beyond reputeRockyMtn.Kris has a reputation beyond reputeRockyMtn.Kris has a reputation beyond reputeRockyMtn.Kris has a reputation beyond reputeRockyMtn.Kris has a reputation beyond reputeRockyMtn.Kris has a reputation beyond repute
  #14
Old 11-15-2008, 07:11 AM
MJay MJay is offline
Currently: Not set.
Basic Member
MJay will become famous soon enoughMJay will become famous soon enoughMJay will become famous soon enoughMJay will become famous soon enoughMJay will become famous soon enoughMJay will become famous soon enoughMJay will become famous soon enoughMJay will become famous soon enough
  #15
Old 11-15-2008, 11:13 AM
dubbs dubbs is offline
Currently: Selling the turbo kit time for a new avatar
dubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond reputedubbs has a reputation beyond repute
  #16
Old 11-15-2008, 04:25 PM
ps700 ps700 is offline
Currently: Uggh back to work!!!
ps700 has a reputation beyond reputeps700 has a reputation beyond reputeps700 has a reputation beyond reputeps700 has a reputation beyond reputeps700 has a reputation beyond reputeps700 has a reputation beyond reputeps700 has a reputation beyond reputeps700 has a reputation beyond reputeps700 has a reputation beyond reputeps700 has a reputation beyond reputeps700 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
