Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 03-10-2019, 05:24 PM
EJCmoto EJCmoto is offline
Currently: Not set.
Basic Member
EJCmoto is an unknown quantity at this point
Default 155/174 swap theory
So I was originally going to make my sled a 163. Currently a 155 3" and needs a new track and rails anyway. So looking at what Burandt claims, that hes running a 163 on a cut 155 tunnel, how about a 174 swap on stock 155 tunnel?
Just to be clear, where I ride is accessible without trail, and if I do run down the trail it's under 5 miles at the very most. So I'm figuring just running no flap. Curious if anyone has experimented with this combo.
Rate this post: Yes | No
  #2
Old 03-10-2019, 05:40 PM
gonehuntnpowder gonehuntnpowder is online now
Currently: Not set.
gonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond repute
Default
Have to check on mounting points for the suspension you only need the flap for cooling but I expect it may be harder than you think. I Would put a longer bumper on it, hard to lift with the track in the way.
  #3
Old 03-10-2019, 05:50 PM
Currently: Not set.
Basic Member
Default
Quote:
I could see a little longer bumper being helpful. As for the rails ice age makes a direct swap, as the stock 174 ones wont just bolt on my skid.
  #4
Old 03-10-2019, 07:51 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is offline
Currently: Boost is addictive
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
Default
I ran a 163 on a 146 tunnel with no ill effects.
If you want a 174 just go for it.
__________________
Try again
  #5
Old 03-10-2019, 08:22 PM
MKULTRA MKULTRA is offline
Currently: braaapping
MKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond repute
Default
Quote:
if you put a longer bumper it kinda defeat the advantage of having a shorter tunnel
who lift their sled by the bumper when stuck? you guys must be strong
The Following User Says Thank You to MKULTRA For This Useful Post:
Sheetmetalfab (03-10-2019)
  #6
Old 03-11-2019, 07:34 AM
Currently: Not set.
Basic Member
Default
This is a very good point. I never lift by the bumper when stuck. Just nice for my crank lift stand when doing maintenance. But I've got a sled lift so no big deal.
Think I'll just buy rails and a track and see what happens.
The Following User Says Thank You to EJCmoto For This Useful Post:
Sheetmetalfab (03-11-2019)
  #7
Old 05-10-2019, 09:32 PM
xpspenziv's Avatar
xpspenziv xpspenziv is offline
Currently: boooasting
xpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond repute
Default
174 drop brackets are farther back on the tunnel. Approx 3-4". Torque arms are different lengths, front and rear torque arms have there own mounting locations. A 155 uses the same location for both. I'm in the process to go from 174-163. Polaris does not sell just drop brackets and no aftermarket. The tunnel has extra bracing at the drop bracket location.
  #8
Old 05-10-2019, 09:36 PM
Default
Quote:
If the 174 use the same bracket just different spacing their is aftermarket brackets
  #9
Old 05-11-2019, 09:55 AM
richracer1's Avatar
richracer1 richracer1 is online now
Currently: Doing the Sidekick Switch
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
Default
Kmod has replacement HD drop brackets.
https://www.kmodsnowmobileparts.com/...12586274979934
__________________
  #10
Old 05-11-2019, 10:42 AM
TRS's Avatar
TRS TRS is online now
Currently: 2019-2020 winter on the way
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
Default
I would have custom IceAge rails built. 174” configuration at a 163” length.
The Following 2 Users Say Thank You to TRS For This Useful Post:
Sheetmetalfab (05-11-2019), xpspenziv (06-23-2019)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 155-163-174 WHICH ONE Thread Starter — NWaxys Forum — Polaris: AXYS Replies — 31 Last Post — 03-22-2017 12:01 AM
Thread — Sled Comparison: Ski-Doo 174 – Axys 155 – Pro 155 Thread Starter — tuneman Forum — Polaris: Pro-Ride Replies — 4 Last Post — 02-19-2016 12:46 PM
Thread — Stretching a 155 to a 174 Thread Starter — niner Forum — Polaris: Pro-Ride Replies — 21 Last Post — 06-15-2015 10:31 PM
Thread — 2011 Assault 155" track for sale. WTB/swap for Pro RMK 155" track Thread Starter — mxranger Forum — Tracks (Swapmeet) Replies — 0 Last Post — 01-06-2011 11:20 PM
Thread — swap a 163 for a 174 Thread Starter — goboji1 Forum — Tracks (Swapmeet) Replies — 0 Last Post — 03-31-2010 09:05 PM
no new posts
