Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 01-27-2019, 03:26 PM
WIMPY WIMPY is offline
Currently: BEEN HERE SINCE 09-26-2001
Basic Member
WIMPY has a reputation beyond reputeWIMPY has a reputation beyond reputeWIMPY has a reputation beyond reputeWIMPY has a reputation beyond reputeWIMPY has a reputation beyond reputeWIMPY has a reputation beyond reputeWIMPY has a reputation beyond reputeWIMPY has a reputation beyond reputeWIMPY has a reputation beyond reputeWIMPY has a reputation beyond reputeWIMPY has a reputation beyond repute
Default Silber’18 axys Munster(install) throttle tss removal??
Ok maybe a dumb question .. ( was going to call or email silber Monday)
I bought a Munster finger throttle to put on my ‘18 axys silber turbo
When doing this the throttle positioning sensor is removed( disconnected )and replaced with a little Doohickey ... Will this affect any of the readings to the Ecu that the turbo needs to run properly ...?
Rate this post: Yes | No
  #2
Old 01-27-2019, 09:06 PM
sledheadd's Avatar
sledheadd sledheadd is offline
Currently: enjoying the TAxys
sledheadd has a reputation beyond reputesledheadd has a reputation beyond reputesledheadd has a reputation beyond reputesledheadd has a reputation beyond reputesledheadd has a reputation beyond reputesledheadd has a reputation beyond reputesledheadd has a reputation beyond reputesledheadd has a reputation beyond reputesledheadd has a reputation beyond reputesledheadd has a reputation beyond reputesledheadd has a reputation beyond repute
Garage
Default
NO.
__________________
Diamond S Nytro mesh hood 4 sale.
17 TAxys 174" Lime squeeze
13pro rmk163 2.6" 13.1 head Mod shop porting pcv Dynoport pipe ypipe GGB can,extreme vents,MDS, airframes, WRP seat c3 beltdrive 8"led light 7"powder hounds, stage5 elka shocks,alt impact a arms- 162"CE2.5" T-nytro mcx, full mod only the plastic is stock.
The Following User Says Thank You to sledheadd For This Useful Post:
WIMPY (01-28-2019)
  #3
Old 01-27-2019, 09:20 PM
sledhead9825 sledhead9825 is offline
Currently: Not set.
sledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond repute
Default
Quote:
Originally Posted by sledheadd View Post
NO.
TPS... Throttle Position Sensor.
TSS... Throttle Safety Switch.
The TSS is removed with a Munster Finger Throttle. Not TPS
Make sure you run a Tether if you don't already
Sorry edited wrong post. It was for the OP
The Following User Says Thank You to sledhead9825 For This Useful Post:
WIMPY (01-28-2019)
  #4
Old 01-28-2019, 12:53 AM
Basic Member
Default
Thanks guys! And yes I already run a tether
The Following User Says Thank You to WIMPY For This Useful Post:
sledhead9825 (01-28-2019)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Silber axys 800 rmk install sidepanel interference Thread Starter — Dzurowsk Forum — Polaris: TURBO Replies — 5 Last Post — 03-08-2019 08:01 AM
Thread — Axys Throttle body adapter with Silber Turbo BOV hole Thread Starter — wfieldin Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 02-23-2018 07:03 PM
Thread — Silber turbo install? 2016 Axys Thread Starter — rockin rmk Forum — Polaris: TURBO Replies — 7 Last Post — 02-19-2018 08:12 PM
Thread — Installing silber turbo on 16 axys what should I do/check before install? Thread Starter — Prormk99 Forum — Polaris: TURBO Replies — 7 Last Post — 10-17-2016 12:11 PM
Thread — AXYS SILBER TURBO INSTALL...in under 48 minutes Thread Starter — tudizzle Forum — Polaris: TURBO Replies — 14 Last Post — 02-22-2016 08:51 PM
no new posts
