M
I am going to drill out the holes on the weight to insert a bushing. This will eliminate the need for a set screw(which always fails) it will also eliminate the friction of the o-rings allowing for faster weight movement. Spacers will be needed to keep the weight in the center of the roller.
My question is will this change the weights I need?
To me this seems such an obvious easy fix, I cannot believe no one else has done it. This will make it operate like a polaris clutch.
I would experiment, but there is no snow here and I want it to work when I go on my trip.
