L
What does everyone do to there sleds every year for your pre-season maintenance?
Im going to have my mechanic clean my power valves, clean my clutch, change my DD fluid, check track tension, and just give everything a good checkup. Im too lazy to do it myself haha, and i have to have him put a couple parts on that i dont know how to anyway.
Pressure wash
Wax
WD40 the exhaust
Remove the DD, open the case, clean/inspect, reassemble
Adjust track tension
Clean clutches
Adjust belt tension
Adjust toe-out
Tighten upper steering block bolts
Adjust Float pressures and check skid spring setting
Check wire harness for rubs, pinches,...
Adjust throttle cable
Clean inside of airbox
Still running original plugs @ 1100 miles, they still look nice and brown - Maybe I'll change them this year
Original belt as well, perhaps I'll swap it with the new spare...hmm...
Top off gas and oil
Wait 10 more weeks for pull the rope and go!
so, my big question is can you just pressure wash everything under the hood? do you cover anything up or try to avoid any areas?
What???? I better not have to wait that long!!!! More like 4 to 5 weeks!:beer;
