Question about thermostats?
R
Jan 28, 2018
21
1
3
68
Why do the thermostats for two strokes come in the 130 to 140 degree range but the four stroke thermostat are in the 170 degree range? I have two on the shelf, one for a carb heater from Avid and one for a set of Raze heated handlebars.
wwillf01
2,790
616
Heber Ut
Those are where the engines run better temp wise. That being said I have ran a 2 stroke with the 170 and it has been fine because I use raze handlebars.
M
Jan 14, 2004
3,079
1,390
The FI 4 stroke likes to be over 170 degrees which keeps it from going into the cold loop ie: 5:1 AF ratio and over fueling the bike which also cools the bike down, double bad. Carbed 4 strokes don't care as much as the fuelies. 2 strokes seem to max out power wise at about 120 degrees, there are no over fueling concerns though. There is no substitute for a good temp gauge.
M5
