R
Hey guy's where are you running your oil levels on these, when checking per MPI's recommendation of running up to a minimum of 150 degrees or up to fan on and shutting down and timing to a min of 30 seconds and then checking my tank was nearly full to the top so I sucked out about 350 to 400 ml and when following the same procedure I'm now at the very top end of the normal mark on the stick and that's threaded all the way in when checking. It was obviously over full but I'm just looking for some other's thoughts and experiences with this on their Vipers?
