Belt deflection
sledhead_24_7
2,482
1,006
Jackson Wy
When taking apart and reassembling the Pdrive you need to make sure the weight tip are resting in their slots around the spring. As well as the sheeve rollers in the proper slots.
You may have done do, just thought I’d mention, in case not.
A
ak
2,776
723
Yep that’s what I was getting to. Something is wrong on the reassembly of the p -drive.
H
Dec 7, 2009
44
7
8
I had the clutch off and took it to the dealer. They said they had to make some “adjustments to it. This was about 3-4 wks ago. Clutch is still the same as before. It works fine just can’t set the deflection how it’s supposed to be.
Devilmanak
4,982
2,193
Donnelly, ID
So if it was right and then you changed something, like a clutch kit, and then it was wrong, then it is pretty obvious that something was assembled incorrectly?
kanedog
Undefeated mountain clutching champ of the world.
3,106
3,861
.015" or 15 thousandths of an inch for belt to sheave clearance.
To sound cool, say 15 thou.
Have you been able to ride it since the belt deflect debacle?
Sent from my SM-G920W8 using Tapatalk
PaulAnd
2,186
586
Northern IL.
Did you take secondary apart also?
Maybe your secondary shaft is not seated in the retainer properly.
H
Dec 7, 2009
44
7
8
Update... I picked up a new damper/cushion drive. Measured the taper on mine vs the new one. The new one was a bigger taper. Put it on and problem solved. The screwed up taper was going too far in the fixed sheave and taking away all belt to sheave clearance.
M
Dec 17, 2016
78
Northern Illinois
Glad to hear you got it fixed! Also, Thanks for posting your solution. I hate when people present a problem and never post the solution or outcome.
K
kovs
65
9
8
saskatchewan
I have this exact problem. Sled has 225 miles on it. Changed out spring in primary and put back on and I have no belt clearance when it’s torqued to spec 89 ft lbs
I ordered a new cushion. As dealer had never experienced this yet- they want to see clutch when I come pick up part maybe warranty. Lol
but I see even DJ has now on his sled experience this so ...
JH@CM
493
769
93
Broken, improperly installed, or defective secondary spring?
